Results 1 to 10 of 19
Thread: Timing belt change
    Regular Member Swatty's Avatar
    Jul 2006
    greenock
    Default Timing belt change
    Forgot to mention that when I was picking up the car tonight we got into a discussion about timing belts.
    The mechanic showed me a data sheet/handout (from Vauxhall) they have stuck on the wall that quotes various long intervals for changing the timing belts (typically between 60k and 80k miles over the vaux range). The caveat on the bottom says that vaux recommend changing the belt every 40k miles for their 24 valve engines (even though I think it is officially something like 80k).
    48k at the moment, guess what I’m doing next week
    too right.. it's a must in between 35 - 45K in my opinion...
    and don't just stop at the belt, change the rollers and tensioners as well...
    Regular Member Harry's Avatar
    Uxbridge, London
    well mine has just rolled into 35,000th mile, so how much am i looking at for the belt, rollers and tensioners?
    anybody with a 3.0 diesel done this already?
    Stand by for a spanking H, as VX don't even list it in trade club..so it's gonna be dear....
    You'll prob find thou, that most folks follow the original guidelines and won't have put a belt on thier cars yet..me?.. i'm just over cautious, but a belt kit is cheaper than a new engine..
    Uxbridge, London
    oh goodie(!)
    if i actually do it then i'll want it done before the irmy trip....so i better get ringing around.
    Jul 2006
    greenock
    I was planning to get the whole lot done Mark, I used to do that with the vec B which had the same weakness points (you would think things would improve).
    It’s pretty cr@p that vaux publish one set of figure but fire out some small print to cover their @ss.
    Out of interest is the water pump still driven of the timing belt on the 3.2, if it is any ideas what mileage I can expect from the pump.
    the pump is driven off the auxilary serpentine belt... for the amount of aggro a leaking one can cause, i actually change them at the same time as the belt as the amount of stripping to do a pump is the same as doing a belt... so while you're there it'd make good sense...
    the pumps normally fail by leaking from the bearing gland seals.. there is quite a belt wrap on them in one direction of pull, so it tends to pull the shaft over quite hard..
    Jul 2006
    greenock
    Thanks Mark
    Regular Member ukanalyst's Avatar
    Jul 2006
    Cheshire
    Quote Originally Posted by Harry View Post
    oh goodie(!)
    I'd be really interested if you manage to get costs for this Harry
    Dave
    Uxbridge, London
    3 quotes in and this is how they stack up:
    £289 - Vauxhall Hayes
    £399!!!!! - Vauxhall Harrow
    £270 - Vauxhall Slough
  1. Help :( low mpg after timing belt change
    By tipsy in forum Engine & Drivetrain
    Last Post: 12th May 2012, 19:02
  2. Timing belt change
    By larrysSRI in forum Engine & Drivetrain
    Last Post: 18th April 2012, 11:15
  3. Gsi timing belt change
    Last Post: 1st February 2012, 13:30
  4. timing belt change
    By sri matt in forum Engine & Drivetrain
    Last Post: 3rd January 2012, 18:25
  5. when to change the timing belt
    By pmitchell in forum Vectra C / Signum Car Chat
    Last Post: 1st January 2011, 12:42
