Results 1 to 10 of 24
Thread: wheel spacers.
    Jul 2011
    UK
    Year : 06
    Default wheel spacers.
    How much should I go 10mm or 20mm on rear.
    scottish region
    Leave as is
    Jul 2011
    UK
    Year : 06
    Even when it gets lowered won't the wheels look to far in
    Regular Member hothatch's Avatar
    Nottingham, emec#7
    Vehicle : Mazda 6
    Trim : SE L Lux Nav+
    Engine : 2.0 Skyactiv-G
    Year : 2019
    I read somewhere its best to go for hubcentric spacers. They start on 15mm.
    Regular Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    12 Post(s)
    Vehicle : Insignia
    Engine : 1.6T SIDI Petrol
    i used 20mm hubcentric spacers and the car was lowered 30mm.. it was spot on..
    Regular Member ScotsDragon's Avatar
    Aug 2009
    Lost in Time and Space...
    Trim : SRI
    Engine : 1.9 CDTI 150
    Mileage : 50000
    Just a bit of useless info, According to this spec sheet the rear wheels are 5mm per side further in than fronts,
    Jul 2011
    UK
    Year : 06
    @Caveman_nige you got any pics
    I'm defo getting some as u say on that graph there 5mm shorter and u can tell
    Regular Member d_ghedia's Avatar
    Oct 2007
    Berkshire
    Vehicle : Vauxhall Signum
    Engine : 1.9 CDTI 150. Manual
    Quote Originally Posted by ScotsDragon View Post
    Is the same for estate and signum? I am convinced that the signum has a wider body at the back (and therefore a wider track)
    Hanging Heaton
    35 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 140k
    25mm rear and 16mm fronts on mine, could even do a few more mil if pushed it... I'd lower first then do a plumb line, then go for the look you want... There is a 9mm difference iirc front to cack hence my custom ones
    Jun 2009
    South Coast
    12 Post(s)
    Vehicle : Insignia
    Quote Originally Posted by marc vectra sri View Post
    hmm not to hand as I am at work.. if you do a search for wheel spacers on here you will come across a few threads already where lee and I have posted pics on the cars with spacers.. there may be also be some in the link to the garage in my sig below
  1. Wheel spacers ,yes or no?
    By pogo in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2013, 12:40
  2. wheel spacers
    By decks in forum Vectra C / Signum Car Chat
    Last Post: 5th June 2012, 20:55
  3. wheel spacers , has anyone?
    By melvyn8181 in forum Styling
    Last Post: 12th October 2011, 10:26
  4. wheel spacers
    By hairy31 in forum Handling & Braking
    Last Post: 27th June 2010, 14:33
vectra c wheel spacers
https:www.vectra-c.comforumshowthread.php185461-wheel-spacers
vauxhall vectra c wheel spacers
pogo vectra
what spacers fit vectra sri
vauxhall wheel spacers
wheel spacers vectra c mkii
vauxhall vectra vxr 5mm spacer
vauxhall vecra c wheel hub spacer
vectra cdti 150 spacers
vectra c spacers
vectra c with wheel spacers
Vectra wheel spacers
