Results 1 to 3 of 3
Thread: limp mode
    Regular Member fiend61's Avatar
    Nov 2011
    york
    Vehicle : vectra 2.8 turbo
    Trim : elite
    Engine : 2.8 turbo
    Default limp mode
    hi all
    poddling along at 60mph today when car (vec-c 3.2 ) went into limp mode eml light flashing and no power, pulled over and car sounded like a bag of spanners misfiring, turned off and had a look under bonnet (not alot to see under a 3.2 bonnet) got back in car and started her up, car with spanner light came on and didnt go off until car started, think this is normal when a code is stored, anyways got home and done pedal trick and got code 0302-cylinder 2 misfire detected, now the car has been ok whilst driving home no limp mode or anything absolutley normal so am i best ripping half the engine out to check spark plugs etc or leave it until it happens again??? also is there anything else that i can do to try and find out why this has happened
    TIA
    Nov 2011
    york
    Trim : elite
    Engine : 2.8 turbo
    having to bump this as i need advice im off work this week and if i need to do anything now is the time
    tia
    prestatyn
    only you can asnswer that but me personally there's a reason why it happend, I would wait till it happens again unless your doing long distances as theres no point in stripping it all to change a plug when theres a good chance it could be a coil pack,injector or plug cant see it being compression as it's running fine again but theres no harm in doing a test to see what compression your getting while it's apart
  1. Limp mode.... Help
    By jodiexii in forum Y & Z30DT Specific
    Last Post: 2nd July 2012, 09:45
  2. Limp mode!!! HELP
    By J's Turbo in forum Engine & Drivetrain
    Last Post: 14th October 2011, 15:06
  3. limp mode still
    By trickster75 in forum Engine & Drivetrain
    Last Post: 24th July 2010, 22:03
  4. Limp Mode
    By frenchman in forum Engine & Drivetrain
    Last Post: 25th October 2009, 21:35
  5. Limp mode or dead mode
    By JSYSH466Y in forum Engine & Drivetrain
    Last Post: 2nd July 2009, 09:46
vectra c 3.2 in limp mode
