Results 1 to 10 of 11
Thread: Any tips on changing rear springs
    Regular Member triple595's Avatar
    Mar 2011
    llandrindod wells
    Default Any tips on changing rear springs
    Got to fix my broken spring at the w/e any tips to make it easy
    the haynes manual says I need to remove caliper and replace the bolts?
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Undo shock bottom bolt, undo lower arm bolt push down on lower arm at same time pull spring out.
    refit in reverse
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Always remember the Haynes manuals take into account manufacturer recommendations, so undamaged bolts that are not typically subject to high forces will probably be perfectly fine to re-use, while if done following the manufacturer's recommendations, they'd be looking to sell you new fittings as well as replacement units.
    Little dab of threadlock might be an idea when refitting though.
    Engine : 1.9 CDTi
    Quote Originally Posted by Critch View Post
    refit in reverse
    Any force/jack needed as I want to replace my rear Ebiach ones for some not so low and cant remember if I did it on a ramp or outside my house.
    Regular Member Keif's Avatar
    In the Garage
    Don't need to touch the caliper. As @Critch says, undo two bolts and spring will come out (with a bit of fighting).
    Personally, i'd jack up the back end and sit it on axle stands, then with the new spring in, jack the lower arm into position to align the bolt hole.
    wirral
    61 Post(s)
    Trim : Basic
    Engine : 1.9
    Quote Originally Posted by lee gsi View Post
    Not massive amount mate easy as anything on ramp
    id use a bar an just put bit of leg pressure at sane time if doing it on stands.
    a second person makes it less awkward.
    but it is easy enough on ya own just pull on spring as you stand on bar that's levering lower arm.
    Mar 2011
    llandrindod wells
    Cheers guys sounds a lot easier than in the manual lol, be good to keep busy after recent events
    13 Post(s)
    Quote Originally Posted by triple595 View Post
    any tips to make it easy?
    Yes, read the HOW2
    Mar 2011
    llandrindod wells
    Thanks I did a search but didn't find it
    13 Post(s)
    First place I always look is in the HOW2 INDEX
  1. Cost of changing rear springs
    By gekornro in forum Vectra C / Signum Car Chat
    Last Post: 7th July 2018, 18:02
  2. Changing rear brakes tomorrow, any tips?
    By SRI456 in forum Vectra C / Signum Car Chat
    Last Post: 12th June 2010, 23:53
  3. Changing sri exhaust tips
    By craig1989 in forum Styling
    Last Post: 26th May 2010, 19:36
  4. any tips on how to cut the rear valance to show my exhaust tips
    By eaglepva in forum Vectra C / Signum Car Chat
    Last Post: 2nd July 2008, 18:58
  5. Changing rear siggy springs, is this the bolt to undo
    Last Post: 26th February 2008, 04:44
changing vectra c rear springs
replace rear coil springs vectra c
hos to remove rear springs vectra c estate
vectra c which way should the rear springs be seated
