Results 1 to 10 of 13
Thread: Cdti 120 high fuel consumption
    Mar 2013
    liverpool
    Vehicle : '04 (54) vectra sri cdti 120
    Trim : sri
    Engine : z19dtl
    Mileage : 178000
    Default Cdti 120 high fuel consumption
    Hi, my 54 plate vectra sri cdti 120 has all of a sudden gone really **** on the fuel, i watch the range going down mile by mile as im driving along it will drop about 10 miles for every mile i drive, and i got about 150 miles to half a tank, thats driving it responsibly aswell lol. If im on the motorway at 70 mph the range will climb, but as soon as i start driving at round town speeds it drops off rapidly. No eml is on and no codes stored in ecu. Any ideas?
    Sep 2007
    West
    hows the temp guage? could be the thermostat
    Regular Member Angel1368's Avatar
    Mar 2012
    liverpool
    34 Post(s)
    Trim : VXR
    Engine : 2.8 V6 turbo
    Mileage : 44,000
    must admit mine does this also and the temp gauge hadly ever moves
    Regular Member greza1066's Avatar
    Nov 2010
    barnsley
    Vehicle : vectra c
    Trim : cdti sri
    i was getting around 41 mpg average in mine till i cleaned egr valve and the little sensor at the side of it (is it the boost sensor) now getting 49.5 mpg average.
    plus check you dont have a sticking rear brake caliper holding you back as well cos this effects the mph as well
    Mar 2013
    liverpool
    Trim : sri
    Engine : z19dtl
    Mileage : 178000
    My temp guage doesnt go up at all unless stuck in traffic but it wont go above 80
    Regular Member any-mgzt's Avatar
    Jul 2008
    cheshire
    21 Post(s)
    Vehicle : Vectra C
    Trim : basic
    Engine : Z19DT
    Change the thermostat it will heat up quicker, as for the consumption I have no idea, mine was better on consumption before I changed the stat, although i only dropped a couple of MPG, most of my driving is motorway anyhow. Have any codes read anyway may be something there that has not caused the EML to come on.
    Jan 2011
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 167340
    Quote Originally Posted by jiffy1986 View Post
    your thermostat should read around 86 and stay there unless you put your heater on say setting 4 then drops a little
    diesels do take longer to heat up but i would change the thermostat its a common fault on the vectra c 120 150 and 1.8 petrol
    i believe the 120 is a bit awkward to change
    Mar 2012
    liverpool
    34 Post(s)
    Trim : VXR
    Mileage : 44,000
    as i say mine doesnt really move at all on my 120, is it bad to keep it this way till i get some money together?
    Jan 2011
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 167340
    Quote Originally Posted by Angel1368 View Post
    pm sent
    Mar 2013
    liverpool
    Trim : sri
    Engine : z19dtl
    Mileage : 178000
    Have scanned it with my snap on solus pro scanner and there are no faults stored. Will get the stat changed and see how it goes!
  1. Replies: 1
    Last Post: 22nd October 2012, 07:55
  2. Intermittent high fuel consumption
    By wookie in forum Engine & Drivetrain
    Last Post: 26th April 2012, 22:10
  3. 3.0 cdti fuel consumption
    By fralolit in forum Y & Z30DT Specific
    Last Post: 15th November 2011, 15:19
  4. why the high fuel consumption?????
    By richje100 in forum Engine & Drivetrain
    Last Post: 27th March 2011, 20:28
  5. Fuel Consumption seems high, Signum 2.0 Deisel
    By Mad_Matt in forum Engine & Drivetrain
    Last Post: 22nd February 2008, 19:14
