Results 1 to 10 of 26
Thread: Lift-off oversteer??
    Regular Member ThatAudioBloke's Avatar
    Feb 2013
    Newcastle, UK
    20 Post(s)
    Engine : CDTI 150
    Mileage : 103000
    Default Lift-off oversteer??
    I've noticed a couple of times that my car suffers from pretty bad lift-off oversteer, especially around left hand bends.
    I'm hopefully going to get my head under the back end of the car on the weekend to sort the droplinks and ARB bushes (if they ever arrive!) so I'll give the rest of the suspension a wiggle while doing that, but are these cars known to be easily provoked into lift-off oversteer or is it more a symptom of shagged rear end suspension?
    There's also a squeak coming from the nearside rear over bumps, so I'm assuming this will be the inner banana arm bush but to be honest, there's that many squeaks and knocks - I think I'm going to end up having to replace probably all of the rear end bushes before too long.
    I don't think that the squeak will be a factor with this though, as it's the rear right tyre that loads up around right hand bends.
    (It might just be the crap chinese ditchfinders that are fitted to the car though, I'm never ruling that out!)
    Regular Member Slammedorion's Avatar
    Mar 2012
    cheshire
    11 Post(s)
    Banana arms...
    Feb 2013
    Newcastle, UK
    20 Post(s)
    Engine : CDTI 150
    Mileage : 103000
    Banana arms what... are they the cause of the lift off oversteer or the squeak from the rear? (or both?)
    newport
    try slowing down lol
    Feb 2013
    Newcastle, UK
    20 Post(s)
    Engine : CDTI 150
    Mileage : 103000
    Fair comment! It happened today coming off a roundabout though, I was doing no more than 30mph and felt the characteristic shimmy from the back end as the rear offside wheel decided that sideways was a better direction than forwards!
    It's not full on massive sideways action (it is a Vec afterall!) but its enough to feel it.
    I am leaning on the cheapo ditchfinders that are fitted to it as a primary cause though. I hate driving on cheap tyres, so as soon as I decide to get the wheels refurbed I think I'll stick some branded rubber on.
    Of note, it's generally left hand corners that it lets go on - right hand corners (or roundabouts), I haven't had it go once on... and, having been to have a look at the car I think I may have found why!
    Front R/L - Prestivo (cheapo but ok unless you push it)
    Rear Left - Kenda (cheapo but not completely terrible)
    Rear Right - Infinity INF05 (oh dear... http://www.tyrereviews.co.uk/Tyre/Infinity/INF-05.htm check out the grip characteristics of these badboys!!!)
    West
    Check the banana's for play, they usually knock rather than squeak... replace the ditch finders (tyres)
    Sep 2012
    expat Lancashire lad in the Midlands
    Engine : 3.2
    catch it with a dab of oppo and then you're away.
    It will need new rear Dampers Classic symptoms on a Vec C !!!!!
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    Only time I've ever had anythinbg like that was when I stupidly put my mobility scooter right on the tail, instead of up against the back seat. Tail tried to race the front end round the first roundabout.
    I'd suspect the tyres - but what suspension do you have? Mine's the lowered SRi one
    Feb 2013
    Newcastle, UK
    20 Post(s)
    Engine : CDTI 150
    Mileage : 103000
    If the ARB bushes arrive by the weekend, I'll have a poke around all of the bushes while I'm fitting them.
    It certainly doesn't feel like driving on burst shocks, it's very compliant on the road in general.
    It has the sri factory lowered suspension (I believe, anyway). First steps are to poke around with a pry bar and ditch the ditchfinders I think!!
  1. Post face lift stereo into pre face lift vectra
    By charwood23 in forum Electrical & ICE (including SatNav)
    Last Post: 5th March 2013, 21:11
  2. A lift
    By gaz1965 in forum Comedy & Humour
    Last Post: 9th April 2012, 13:32
  3. Pre-face Lift & Face Lift Auto dimmin Rear View Mirrors
    By Meady in forum Electrical & ICE (including SatNav)
    Last Post: 16th May 2011, 16:25
  4. Pre-face lift vs Face lift performance figures
    By larrysSRI in forum Vectra C / Signum Car Chat
    Last Post: 5th November 2009, 23:11
  5. car lift
    By fingers66 in forum General Chat
    Last Post: 29th April 2009, 16:09
ford mondeo 2009 oversteering
mondeo oversteer roundabour
