Results 1 to 2 of 2
Thread: Screeching from engine compartment
    Regular Member ads3's Avatar
    Northants
    Engine : 2.0 DTI
    Mileage : 86,000
    confused Screeching from engine compartment
    Hi,
    My 2005 Vec C 2.0dti makes a screeching sound (like a slipping belt) from 1500rpm both driving through each gear and also in neutral. It has done it for abot 2 1/2 years straight after a new diesel pump was fitted, dealer couldn't find anything wrong.
    However it has recently started getting worse so when it went in for an MOT I asked them to investigate, they have since said it could be the diesel pump! Is this so?
    Work carried out on my Veccy so far includes new; diesel pump, turbo, egr valve, all 4 springs, injector seals (twice), to name but a few, as well as run-of-the-mill stuff, brakes, tyres etc. etc. etc.
    Northants
    Engine : 2.0 DTI
    Mileage : 86,000
    Forgot to say Veccy has done 86,000 miles!
  1. screeching when starting ??
    By mccluskey119 in forum Engine & Drivetrain
    Last Post: 9th August 2011, 23:52
  2. What does fuse 26 do in the engine compartment fuse box?
    By rich05uk in forum Vectra C / Signum Troubleshooting
    Last Post: 8th January 2011, 22:02
  3. Engine Compartment Fusebox
    By GazVXLINE170 in forum Electrical & ICE (including SatNav)
    Last Post: 1st September 2010, 11:23
  4. Where is Ignition Wire located in the engine compartment?
    By the-converter in forum Electrical & ICE (including SatNav)
    Last Post: 22nd January 2010, 07:07
  5. Knocking and screeching
    By Fulgrim in forum Vectra C / Signum Troubleshooting
    Last Post: 12th May 2008, 17:42
