Thread: vectra c airbags
    Jan 2013
    glasgow
    Vehicle : Vectra c
    Default vectra c airbags
    hi guys just bought a second hand air bag ecu and i got these codes
    hkj
    hkj
    OP-COM - CAN Communication Window> 2005|Vectra-C / Signum|Body|SDM (Airbag)
    Read Info...
    Identifier: 0x0102
    VIN: W0L0ZCF6861118673
    Part Number:13186947
    Software version number: 0C0D4B11
    Alpha code: KN
    Total number of fault codes: 8
    B0012 - Driver Airbag Squib Circuit (Stage1) High Resistance
    (0D) - Not present
    B0013 - Driver Airbag Squib Circuit (Stage 2) High Resistance
    (0D) - Not present
    B0015 - Driver Pretensioner Circuit High Resistance
    (0D) - Not present
    B0019 - Passenger Airbag Squib Circuit (Stage1) High Resistance
    (0D) - Not present
    B0020 - Passenger Airbag Squib Circuit (Stage 2) High Resistance
    (0D) - Not present
    B0022 - Passenger Pretensioner Circuit High Resistance
    (0D) - Not present
    B0051 - Squib Circuits Activated (Crash)
    (00) - Present
    U2139 - Invalid Data from CIM (Steering Column Module)
    (7F) - Not present
    tried to clear these with my op-com but wouldnt clear! can anyone tell me what these are and how they can be cleared? and you see from the rest of the codes they are not present only the squib circuits are present.so could it be my car or the car its been taken off? as i know the ecu locks after a crash and stores all the coded.
    Nottinghamshire
    This any help?
    Regular Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    12 Post(s)
    Vehicle : Insignia
    Engine : 1.6T SIDI Petrol
    now send your original one off to be cleared or find somebody with Tech2 (and knows what they are doing with it, so forget the dealers) who can do it on the car..
    Are your pretensioners activated? Sounds like you may also need to check that your airbags are actually installed. If you car has been in an accident before some so called repair places will fit a new dash but not fit new airbags, i have see this happen..
    Administrator plasma's Avatar
    On the Forum
    538 Post(s)
    Engine : 150
    Mileage : 74000
    start at the beginning, why are you changing your airbag ECU to begin.. This system needs to be done right as your life depends on it
    Jan 2013
    glasgow
    Vehicle : Vectra c
    Hi the ecu wasn't in the car I expect the car had a crash before I bought it but not sure as wasn't told and not on v5. But have checked full system and all seems ok.the only thing confusing me is the squib circuits.
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Pretty certain all SRS fault codes can only be cleared using legitimate Tech II equipment. Unlike 'non-safety system' faults that either clear themselves after a number of 'clean' starts, or can be cleared by 'computer based applications', code readers, or in some cases just by leaving the battery off for a while.
    On the Forum
    538 Post(s)
    Engine : 150
    Mileage : 74000
    ok i think i misread the codes before, they should all clear except the crash data one which should be able to be clear with tech2,
    Jan 2013
    glasgow
    Vehicle : Vectra c
    Ty. All for the help
    On the Forum
    538 Post(s)
    Engine : 150
    Mileage : 74000
    report back, let us know how you get on..
  1. airbags
    By Martin_UWF in forum Vectra C / Signum Car Chat
    Last Post: 11th August 2012, 19:34
  2. Vectra C SRi 3L V6 CDTi Airbags
    By smitd004 in forum Electrical & ICE (including SatNav)
    Last Post: 17th April 2011, 08:45
  3. airbags
    By stevejames199 in forum Vectra C / Signum Car Chat
    Last Post: 27th January 2008, 19:57
  4. airbags!!
    By stevejames199 in forum General Chat
    Last Post: 27th January 2008, 02:03
Vauxhall B0015-0D
B0020 vectra c stage 2
