Thread: Best place for HID kit for 2003 sri pre face lift
    Feb 2012
    Sheffield
    Default Best place for HID kit for 2003 sri pre face lift
    Hi all,
    to save me searching through the many HID threads can anyone reccomend where i can get the HID kit for my 2003 SRI
    as i have seen problems with the bulb fail warnings?
    thanks
    Andy
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    If I remember correctly, a popular choice seems to be HIDs Direct... I'm forever getting them mixed up with HIDS4U... one is decent, the other a bit hit n miss... think I have it the right way around.
    Bulb failure warnings isn't a big problem with HIDs, that's more from LEDs when fitted to sidelights.
    Take a look at : http://www.hids-direct.co.uk/categor...-kits-for-cars
    Gives you plenty to choose from. The choice of 35w or 55w is really down to you... I run 35w 6000k and love it, personally... others will swear by 55w kits.
    Choice of colour temperature is a bigger concern. Personally I'd say either 5000k or 6000k are good... 4300k is supposedly closest to OEM but some can find 5000k gives a more white light, where 6000k can have a slight blue tint.
    Older kits also required 'cancellors' to accomodate for the flicker caused by the lamp check system, but new kits should have a built-in compensation - just make sure you pick a 'Canbus Compatible' kit and if you can, get 'Xenons Present' enabled by someone with a 'computer based application' in your car's ECU.
    Sep 2012
    expat Lancashire lad in the Midlands
    Engine : 3.2
    Get a terminator kit. One like this:
    http://www.ebay.co.uk/itm/NEW-CANBUS...item3a77eb0d40
    or
    http://www.ebay.co.uk/itm/NEW-CANBUS...item3f154ad259
    I have the we-sell-hids kit fitted for about 3 months now and it seems fine, to be fair I think they are all the same whoever you buy off.
    newport
    i bought a kit that had the cancelers built into the ballasts, had no issues what so ever since fitted, will try and find a link, but it was from ebay with only so many available from the seller, so not really much use to you now
    they also came with metal based bulbs which i find lock into the holder alot better than the plastic ones i have bought in the past.
    it was a 6k kit as it was quite a it cheaper than the 4.3k kits i was looking at, but i wanted as standard looking as possible, so bought a set of 4.3k metal based bulbs for about £6 iirc, and sold the 6k on
    Feb 2012
    Sheffield
    cheers for the replies folks, would this kit be any good as it says it comes with cancellers
    http://www.ebay.co.uk/itm/H7-6000K-B...#ht_2340wt_933
    Forum Moderator davedrinks's Avatar
    Sep 2010
    Luton
    30 Post(s)
    Vehicle : Vectra Hatch
    Engine : 1.8VVTi 16v
    Mileage : circa 28K
    I got my kit from HIDs Direct - no issues at all - plus I got an email today saying you can get an extra 10% off until the end of April using coupon code maketen
    Mods : Insignia Washer Jets,Boot & Footwell LEDs,Reverse Cam,Pioneer AVH-3200BT,Pioneer TS-Q172C(front),Alpine MRVT407 V12 Amp,Alpine SBE-1243BR 12" Sub,In Car Freeview TV,Heko Wind Deflectors,Airbox mod,K&N Panel Filter,Irmscher Boot Spoiler,Angel Eyes, 50W 5K HIDs, 30mm Lo lowering springs, Eyebrows,17" Fox Alloys,Powerflow Stainless Steel dual exhaust. Winner-Best I.C.E-Heritage Centre Meet 2013
    13 Post(s)
    Got my HID kit from www.hids4us.com 3½ years ago. Had one bulb failure approx 14 months ago, but £10 for 2 new ones from ebay sorted it. Other than that everything has been fine.
    Loads of threads both dissing and praising hidsdirect. Because of the negative feedback I read about them, I steered clear. Bad customer service, etc.
  1. Post face lift stereo into pre face lift vectra
    By charwood23 in forum Electrical & ICE (including SatNav)
    Last Post: 5th March 2013, 21:11
  2. Will this fit Face lift?
    By stuwieb in forum Styling
    Last Post: 19th January 2012, 20:22
  3. Pre-face Lift & Face Lift Auto dimmin Rear View Mirrors
    By Meady in forum Electrical & ICE (including SatNav)
    Last Post: 16th May 2011, 16:25
  4. Pre-face steering wheel / face lift
    By ROCKATANSKY in forum Vectra C / Signum Car Chat
    Last Post: 14th May 2010, 20:57
  5. Pre-face lift vs Face lift performance figures
    By larrysSRI in forum Vectra C / Signum Car Chat
    Last Post: 5th November 2009, 23:11
