Thread: heater panel
    Regular Member andy_richmond's Avatar
    Sep 2012
    andover
    Trim : sri
    Engine : 2.2 dti
    Default heater panel
    Standard not climate. All interchangeable? How do they work. Rods at back or elec. Think mine isnt using thr whole heat range. Cold before the blue
    Regular Member coldo's Avatar
    Scotland
    Strange fault.... One I have not heard of...
    The pannel (non climate control) has two electrical plugs in the back and is full interchangable with any age of vectra / signum...
    Literaly a 30's job to swap for even the most incompitant DIY'er out there...
    Scotland
    Would the engine themostat failing prehaps be causing this issue...?
    Sep 2012
    andover
    Trim : sri
    Engine : 2.2 dti
    Thermostat is new and temp reaches 88 happily. Also hottest setting is scorching. Turn it down a bit a lot cooler. Better town driving like less outside air is being forced through
    Sep 2012
    andover
    Trim : sri
    Engine : 2.2 dti
    changed the heater controls over, now works fine, odd but at least its an option if anyone has the same issue
    Scotland
    Quote Originally Posted by andy_richmond View Post
    Result... Nice one...!
  1. Heater Control Panel
    By faz3270 in forum Electrical & ICE (including SatNav)
    Last Post: 16th March 2007, 15:33
  2. Heater Control Panel
    Last Post: 1st February 2007, 16:15
  3. heater control panel
    By daviek in forum Bodywork & Interior
    Last Post: 13th October 2006, 21:09
  4. removing the heater panel
    By greeningr in forum Vectra C / Signum Car Chat
    Last Post: 12th March 2006, 10:52
