Thread: Nut size for front stabiliser links/drop links
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    Default Nut size for front stabiliser links/drop links
    Vx dealers supplied the stabilisers (part no. 13237130) and as i was about to start, i checked content, no nuts!!!
    What size nut is it? And should i have washer as well???
    Any recommendations??
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Just use the old ones
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    If it get damaged, wont it be better to use new ones just in case?? Going to attempt now...
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    No problems getting it off with spray... One side off... Took a little force but done... Size 18 nut, 17 for inner bolt.
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Driver side top mount was a pest removing... The inner bolt was worn... Used grinder removed then vice tight and nut removed
    All good now, found driveshaft cv boot need replacing... So that'll be next! Will get new disc brakes front and back with pads... Then all a good un! :-)
  1. front drop links
    By skidmark1 in forum Vectra C / Signum Car Chat
    Last Post: 29th December 2011, 14:17
  2. knocking from front, drop links?
    By martinmack in forum Suspension, Wheels & Brakes
    Last Post: 14th May 2011, 22:43
  3. Front Drop Links
    By PORKBALLS29 in forum Suspension, Wheels & Brakes
    Last Post: 24th October 2010, 10:00
Vectra c droplink nut size
