Thread: Signum boot release fix
    Regular Member Desolation91's Avatar
    Jan 2013
    Chesterfield
    Trim : Elite, Tan leather
    Engine : 1.9 CDTI
    Mileage : 106000
    Default Signum boot release fix
    Hi guys
    tried the search but there is alot of threads with same problem but im stuck on how to get at the motor to strip and clean it.
    i press the button and it doesnt open but if i tap above the button with my palm at will work, but i have to hit it every time to make it work?
    how do i get the boot card off to get at everything,
    also can i get at the number plate lights that way as all the screws are shot...
    si
    Mar 2012
    wakefield
    Vehicle : vectra v6 cdti
    Trim : sri
    Mileage : 70000
    Are you sure its the motor,on my old signum all the problem was,was the plate that you pull to open the boot covered by a rubber skin had bent over time so when you pull it,its not pushing the pin in to release the tailgate
    The cover is held in with i think two screws either side plus one hidden inside the interior handle,then you have to prise it away from the plastic lugs(similar to presstuds)
    Jan 2013
    Engine : 2.0T
    try cleaning the switch first, it gets clogged with road grime and sticks. The need to remove the card was a little intimidating to me after experience with my old Skoda, but it took me less than half an hour start to finish. Theres a how to with pictures around somewhere.
    Jan 2013
    Engine : 2.0T
    Jan 2013
    Chesterfield
    Engine : 1.9 CDTI
    Mileage : 106000
    the two screws on the under side of the boot cover how do i get the covers off to get at the screws? is it the little thin bit or do i pull the whole plug up. dont want to brake them as they are tan and i dont know if i can replace them?
    Jan 2013
    Engine : 2.0T
    if I recall correctly, they're actually clippy things rather than screw covers (I thought the same thing). If you put a small screwdriver in the little slot on the side they lever out quite easily.
    Jan 2013
    Chesterfield
    Engine : 1.9 CDTI
    Mileage : 106000
    ahh nice one cheers ill have to look tomorrow now, better to ask the right way than to damage it lol
  1. Boot release Signum
    By stuk2000 in forum Bodywork & Interior
    Last Post: 25th February 2013, 17:29
  2. Testing the boot release switch on a Signum (Pictures)
    By lee gsi in forum Vectra C / Signum Car Chat
    Last Post: 20th February 2012, 11:53
  3. Signum boot release
    By dave_3 in forum Electrical & ICE (including SatNav)
    Last Post: 16th January 2011, 13:33
  4. Signum Emergency Boot Release
    By O5prey in forum Vectra C / Signum Car Chat
    Last Post: 5th April 2009, 23:44
  5. Boot Release
    By Drew in forum Vectra C / Signum Car Chat
    Last Post: 8th February 2009, 22:34
signum boot release
