Results 1 to 2 of 2
Thread: Rear calliper difference
    Regular Member Swedge's Avatar
    Jul 2012
    Scottish borders
    Default Rear calliper difference
    One of my rear callipers of my 54 plate cdti estate is sticking
    can I only fit a calliper from a cdti or what other models use the same calliper
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    From what I can see, the calipers on pretty much all vehicles using the 1.9 diesel engine are the same. Might be the odd minor difference such as which way a bleed nipple points, but those I've seen on the Renault Trafic van, a Zafira and a Vectra estate all appeared the same to me.... and that engine is used on loads of different makes/models.
    But doubtless someone will know better/have seen far more.
  1. Is the seal for the piston on the rear brake calliper glued on ?
    By siadwel in forum Vectra C / Signum Car Chat
    Last Post: 22nd July 2012, 18:47
  2. seized rear calliper bleed nipple
    By DaveG in forum Suspension, Wheels & Brakes
    Last Post: 23rd April 2012, 23:36
  3. Fluid on the rear brake calliper
    By tony_b in forum Suspension, Wheels & Brakes
    Last Post: 16th March 2011, 13:33
  4. Replies: 3
    Last Post: 23rd February 2008, 22:47
