Results 1 to 2 of 2
Thread: Connectors & Wires
    Hanging Heaton
    35 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 140k
    Default Connectors & Wires
    Are all the pins the same across all block connectors on the Vectra? Can I pick these up from anywhere so I can solder up my own wires?
    Mainly for seat blocks, head unit, GID & the front bumper block...
    When you guys are doing external wiring, what do you use... I've been using thicker speaker wires for LEDs etc, everything worked fine, all wrapped in insulation tape, soldered connectors and with water proof blocks, but some of the wires had corroded white and brittle upon inspection (2+ years)... Guessing a little bit of damp got in when originally fitted, may have to WD40 future connections? Or get better insulated wires? What do you think?...
    Want to refit LED fogs and side lights again, may not use dash feed this time however...
    morecambe
    54 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    speacker wire does it all lmao
  1. What are these two connectors for?
    By Simon_Fuller in forum Vectra C / Signum Car Chat
    Last Post: 28th September 2012, 04:19
  2. What are these wires/connectors for?
    By Caveman_nige in forum Vectra C / Signum Car Chat
    Last Post: 1st September 2010, 19:41
  3. bullet connectors
    By decks in forum Electrical & ICE (including SatNav)
    Last Post: 31st July 2010, 23:09
  4. What are connectors on the CD30?
    By Ant177 in forum Electrical & ICE (including SatNav)
    Last Post: 14th August 2009, 08:31
  5. What are these connectors for?
    By H11LGX in forum Electrical & ICE (including SatNav)
    Last Post: 22nd July 2008, 17:56
