Thread: Strange problem with warning display
    Jan 2013
    Chester
    Vehicle : Vectra estate xp cdti
    Trim : Sri xp
    Engine : 120 cdti
    Default Strange problem with warning display
    As per the title guys... Over the past week or two,the dash display has been popping up a warning about brake lights,.Then today on the dash itself,the bulb indicator display shows that a bulb is blown followed by brake light on the gid.
    And yet every exterior bulb on the car all work fine!
    Anybody got any suggestions as to why this is happening or better still,how to cure it!
    Cheers for any responses in advance
    Dec 2011
    Seaham
    Is this a symptom of the ABS plug contacts being dirty? The plug is in the engine bay.
    Take it apart and clean the contacts, see if it sorts the problem
    13 Post(s)
    Quote Originally Posted by Pwthebaldeagle View Post
    Double check your rear lights. If the tail/brake light fails, then the other tail light takes over the role of tail/brake light instead so you still have a full compliment of working brake lights (providing the lower tail lights haven't already failed)
    ie, when everything is ok - from top to bottom
    Indicator
    Tail light / brake light
    Tail light
    Fog tail light (drivers side only)
    Reversing light
    But when the brake light fails:-
    Indicator
    no light
    Reversing light
    Also, when a bulb is imminently about to fail it can also put the warning light on. Basically the bulb resistance changes enough to put the failure warning up.
    Jan 2013
    Chester
    Trim : Sri xp
    Engine : 120 cdti
    Think this weekend I shall clean all connectors nd change the stop light bulbs too. Hopefully that should cure it
    Regular Member Niall83's Avatar
    Nov 2009
    Belfast
    Trim : Exclusive
    Engine : 18VVT Z18XER
    Mileage : 130k
    Check also the connector going in to the lights for melted wires.
    crook
    when bulb warning light comes up on mine i put new bulb in(90% chance its going to go shortly)
    check connector where it goes onto light for corrosion,also make sure base of bulb holders clean and free from corrosion
    Jan 2013
    Chester
    Trim : Sri xp
    Engine : 120 cdti
    Thanx guys,appreciate the help
  1. Strange Warning Loght Combination....
    By Brummie in forum Engine & Drivetrain
    Last Post: 14th February 2013, 09:29
  2. strange warning light
    By chrissri82 in forum Vectra C / Signum Car Chat
    Last Post: 29th August 2011, 01:25
  3. Computer display showing strange temperatures
    By Nato in forum Vectra C / Signum Car Chat
    Last Post: 13th April 2010, 16:59
  4. warning bulb display
    By goonertopcat in forum Electrical & ICE (including SatNav)
    Last Post: 15th March 2009, 02:40
  5. 2.2 2003 Vectra Strange Warning Light Problem?
    By sophos9 in forum Electrical & ICE (including SatNav)
    Last Post: 26th July 2007, 13:16
