Results 1 to 2 of 2
Thread: Reading fault codes
    Jun 2012
    Baldock
    Default Reading fault codes
    My 2008 1.9CDti (150) Vectra has recently started showing the car with spanner light. I read online that the fault codes can be read using the pedal test but can't seem to get it to work.
    I'm pressing the accelerator and brake down whilst turning the ignition to the second click but nothing happens. Am I doing something wrong? Really dont want to have to take it to the garage if I can avoid it as it's just been serviced and is driving fine...
    West
    I don't think the pedal trick works on the diesels... you could pick up a cheap code reader.
    When does the spanner appear, if its after you have just fired up 1st thing in the morning for a few seconds then it's most likely to be the glow plugs, if it's random & while driving but not going into limp mode then it could be the egr sticking.
    Although without having the code you won't know for sure.
  1. p1792-71 gearbox fault code plus alarm sensor fault codes
    By stu f in forum Vectra C / Signum Car Chat
    Last Post: 13th August 2013, 21:05
  2. Reading fault codes on Vectra C
    By m2yuout in forum Electrical & ICE (including SatNav)
    Last Post: 27th March 2013, 17:21
  3. Quick help needed reading fault codes!
    By Veccy55 in forum Vectra C / Signum Car Chat
    Last Post: 5th February 2013, 17:08
  4. V6 CDTi reading error codes
    By averdigi in forum Engine & Drivetrain
    Last Post: 20th October 2010, 23:54
  5. Reading fault codes on 1.9cdti
    By clightowler in forum Vectra C / Signum Car Chat
    Last Post: 21st June 2010, 22:20
