Thread: CDTi 8v Vacuum Pump Problem
    Regular Member DeeBe's Avatar
    Jun 2011
    South Shields
    confused CDTi 8v Vacuum Pump Problem
    Morning folks.
    My vacuum pump on my car is leaking a small amount of oil from its underside. It's been removed and had the gasket replaced but to no avail. It has reduced how much is leaking but not stopped it. I am at my wits end with it now as all I know is that it's a vital part of my engine. Does anyone have any ideas as to what could be the cause of this? I don't know a great deal of detail about them so don't know what to be looking for really.
    What are the signs of failure? Have I missed something? Clueless!
    Any help will be greatly received with thanks.
    Dave.
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Have you inspected for any signs of cracking & warping when you replaced gasket?
    Jun 2011
    South Shields
    I did on the head but not on the pump itself.
    Jun 2011
    South Shields
    Trying hard to fix it as ECP have them at an eye-watering £118 inc. VAT. Ouch
    Regular Member justin32's Avatar
    Aug 2011
    Basingstoke
    5 Post(s)
    Vehicle : Vectra c SRI Facelift
    Trim : SRI
    Engine : 1.9 CDTI 150
    Have you read the how2 on here as it kind of explains why it leaks.As far as i can make out its the oil from the vacuum pipe that fills it with oil.
    Mine is leaking on my 1.9 150 from the bottom corner,theres always been a dark patch there but in the last month its started to seep out alot.As far as i know its the 2.2 that suffer with this problem more that the 1.9's but its not unheard of.
    Theres a few knocking around on ebay for alot less that the price of a new one but i would investigate first where the oil is comming from.
    Just out of interest how much did you py for the gasket?
    Jun 2011
    South Shields
    I paid a shade over £4 from the dealers. I know it's definitely coming from here. We think it's down to a bent gasket. Having another delivered.
    Aug 2011
    Basingstoke
    5 Post(s)
    Trim : SRI
    it shouldnt matter if the gasket is bent as when you torque it up it will straighten out
  1. vacuum pump cdti
    By mon in forum Engine & Drivetrain
    Last Post: 23rd January 2013, 09:31
  2. Vacuum Pump 1.9 cdti 120
    By mark230678 in forum Parts for sale
    Last Post: 3rd July 2009, 21:39
  3. CDTI Fuel Pump problem
    By bennyk in forum Engine & Drivetrain
    Last Post: 13th July 2007, 16:59
vectra cdti vacuum pump problems
what can vacuum pump failure cause in 1.9 cdti
1.9cdti brake veccum pump leaking oil
vectra 8v vacum problems
vectra c 1.9 cdti vacuum pump gasket
what should a vacuum pump read 1.9 cdti
