Thread: Which L.E.D's can i use(map,side and boot lights)
    Regular Member justin32's Avatar
    Aug 2011
    Basingstoke
    5 Post(s)
    Vehicle : Vectra c SRI Facelift
    Trim : SRI
    Engine : 1.9 CDTI 150
    Default Which L.E.D's can i use(map,side and boot lights)
    Ive done a search on here to find out what bulbs i can replace with L.E.D's without errors or flickering.
    The lights i want to change are:
    Interior map light
    Boot light
    Side lights if possable
    Could somebody kindly post some ebay links so i can get buying
    Regular Member SEANYboi's Avatar
    Dec 2012
    Bourne end,high Wycombe
    5 Post(s)
    Vehicle : Vauxhall vectra
    Trim : Sti nav
    Engine : Cdti 150
    Year : 55
    Mileage : 96000
    Hello mate ,You will need canbus LEDs for side lights,they all flicker.
    Driving with sidelights on stops flickering, and when you lock the car they will prob flicker for upto 15 seconds after
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    I'm pretty sure the boot lamp is a festoon bulb (like a big plug fuse but glass).
    Map reading lamps and sidelight bulbs are capless w5w bulbs. You can swap the interior lamps for LED equivalents but go for a design that 'points' down more than just having SMDs on the two flat sides.
    Sidelights will pulse from the lampcheck unless you have some additional form of resistance to replicate the resistance of a normal incandescent bulb.
    Despite the claims of 'CanBus friendly' or 'CanBus compatible' LEDs, as has been said they will ALL pulse unless additional resistance is fitted.
    North West - Assistant RO Woody's Avatar
    May 2012
    North West (Warrington)
    234 Post(s)
    Vehicle : Vectra C 3.2 Elite Estate Auto Facelifted
    Trim : Elite with loads of "Extras"
    Engine : 3.2 Z32SE
    Mileage : 94,000
    Interior lights can be changed to LED, just be careful with the rear seat lights as there is a strange connection on them that LED's don't "like" unless you carry out a slight mod first. Boot light, glovebox lights also ok for LED's, BUT ANY of the external lighting will flicker with the canbus system including sidelights and number plate lights, can bus LED's or not.
    Aug 2011
    Basingstoke
    5 Post(s)
    Trim : SRI
    Thanks guys
    I brought some LED's for the boot light,it was a 2 inch by 2 inch square covered in LED's but it worked for about 2 days then became very dim and had to revert back to normal bulb,im not sure if it was because they were cheap or not? They came with an adaptor which fitted into the interior map light but that never worked at all so that why im a bit confused with it all lol
    Would these be ok?
    http://www.ebay.co.uk/itm/2x5-SMD-LE...item4602edabb6 for map light?
    http://www.ebay.co.uk/itm/6-LED-239-...item43ab324218 for boot light?
    Think i may pass on the side lights unless somebody has got a link?
  1. side lights and number plate lights
    By antowens in forum Electrical & ICE (including SatNav)
    Last Post: 13th September 2012, 19:59
  2. Led Side Lights Fitted & 2 Rear Fog Lights
    By wardy23 in forum Electrical & ICE (including SatNav)
    Last Post: 12th March 2012, 23:16
  3. led dash lights and side light running lights
    By fjaimo10 in forum Vectra C / Signum Car Chat
    Last Post: 9th February 2012, 21:21
  4. Brighter Lights for side lights, Vectra SRI150
    By 150_SRI in forum Vectra C / Signum Car Chat
    Last Post: 13th July 2011, 23:50
  5. Philips bluevision h7 head lights & side lights brand new
    By davidlewis24 in forum Parts for sale
    Last Post: 19th March 2009, 22:42
