Thread: main beam height.
    Sep 2009
    Glasgow
    Default main beam height.
    hi all fitted 35w 5000k hid kit a week after mot where my headlights were correctly set, but they seem too low, is the standard set up on vectra lights too low, there was a post by duncan i think to raise heights but cant find it. Anyone help, also left beam is set higher than right, sure this is correct but would like someone to confirm
    Nov 2012
    Wirral
    From what I've heard they are low as standard although check the height adjuster on the dash? Left is higher than right to aid visibility of the kerb and not blind oncoming traffic.
    Sep 2009
    Glasgow
    light adjuster fine, still seem low even when set at mot
    Nov 2012
    Wirral
    If you had them set with a light box then they should be spot on mate
    kirriemuir
    not true about light box i had mine set with light box aswell and still to low. followed instruction on height adjusting and 10x better and still ok for mot and in the top part of light box. turn adjuster to no 2, mark a line on wall turn adjuster back down and adjust lights up to that line job done.
    13 Post(s)
    Quote Originally Posted by nokiaman1978 View Post
    http://www.vectra-c.com/forum/showth...ift-headlights
    But this is for adjusting the dip beam, not main.
  1. main beam question
    By patch22 in forum Electrical & ICE (including SatNav)
    Last Post: 20th October 2012, 20:22
  2. Main Beam issue
    By Cruize in forum Electrical & ICE (including SatNav)
    Last Post: 4th December 2011, 16:50
  3. Main Beam won't stay on
    By KevinG in forum Electrical & ICE (including SatNav)
    Last Post: 4th February 2010, 00:14
  4. Main beam bulbs
    By Keithy in forum Vectra C / Signum Car Chat
    Last Post: 11th January 2010, 12:29
  5. Main beam bulbs
    By Bucko in forum Vectra C / Signum Car Chat
    Last Post: 31st January 2009, 20:49
