Results 1 to 10 of 11
Thread: Advice needed please.....
    ijk571
    Guest
    Default Advice needed please.....
    I managed to rip off the front nearside mudflap earlier (don't ask lol). Whilst investigating I noticed grease sprayed all round the inside of the wheel and the suspension/driveshaft components. The rubber gaitor has split. I don't know if happened a while ago or not. Anyway, is the car safe to use? and can I get away with just getting the shaft re packed with grease and replace the boot, or will I need a complete new driveshaft? Sorry for the rambling post... Thanks2013-04-07170903_zps5f68e310.jpg
    PS Does anyone have a part number for the clips that hold the Vx mudflaps on please?
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    As you have no idea when the boot split, you can only guess what possible contamination might have got into the joint and bearings. So I think it's a matter of stripping off the old boot then cleaning and carefully inspecting the CV joint. If you're lucky you may get away with a good clean, lots of grease and a new boot.
    If there are no noises coming from the CV joint then you are safe just repacking with grease (use the proper CV grease) when you replace the rubber boot.
    Engine : 1.9 CDTi
    As said above.
    If no noise just repack and fit new boot.
    Nov 2012
    Perthshire
    Vehicle : Vectra SRI
    Engine : 2.2 16V
    Mileage : 78000
    Don't wait too long, get it sorted asap otherwise>
    ijk571
    Guest
    Thanks. thinking about it, I don't think I'll attempt it myself. It looks fresh so I'm sure it happened yesterday, then only drove 10 or so miles home afterwards. I'll not use the car until its repaired. Hidden drains in muddy verges and large tractors don't mix.....
    ijk571
    Guest
    Is it a job someone with not a lot of experience can do? or best left to a garage?
    Regular Member C-Owner's Avatar
    May 2011
    South London
    For a novice its a messy job, getting CV grease over everything
    You need the right tools to break down the CV joint assembly safely without damaging the track rod end joint and lower ball joint.
    But
    I did a little Nissan Micras CV's this morning, I had to cut the track rod ends and the lower ball joints nuts off as they were all seized on solid,
    fastest and cheapest solution, bear that in mind if you take it on that you might need to replaced other parts as well as the CV boot.
    Also
    I dont recommend this method but it suits a lot of DIY enthusiasts
    http://www.youtube.com/watch?v=iLrGNU_t83Y
    morecambe
    54 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    wtf never sin one of tuem lmao
    Engine : 1.9 CDTi
    Those glue together ones dont last more than a few months.
  1. Advice needed please
    By davehindley in forum Vectra C / Signum Car Chat
    Last Post: 21st November 2012, 22:27
  2. Help advice needed
    By chrisvectra in forum Engine & Drivetrain
    Last Post: 8th October 2011, 11:28
  3. Help or advice needed...
    By axelf in forum Vectra C / Signum Car Chat
    Last Post: 13th March 2011, 00:15
  4. Advice needed please :)
    By edwardabud86 in forum Suspension, Wheels & Brakes
    Last Post: 30th January 2011, 16:03
  5. Advice needed....
    By jamesr in forum Vectra C / Signum Car Chat
    Last Post: 19th July 2007, 16:19
