Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
Thread: Heated Front Seats?
    Hanging Heaton
    35 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 140k
    Default Heated Front Seats?
    So the SRI leathers are in, but the switches won't light and heat not working, so what to do now?...
    A few names have been suggested for me to contact to have a aftermarket loom made up, but before I do that mine is a preface and it does have the rear loom heated switches under the arm rest... So should mine already have the loom in and maybe its just a missing fuse or relay, rather then a lack if wiring?
    Hope its not the latter...
    Regular Member daddyjay's Avatar
    Jan 2010
    poole
    Vehicle : vectra facelift
    Trim : sri
    Engine : z20net 2oltr turbo
    Year : 57
    Mileage : 38200
    have you tec 2 mate. need programming
    Hanging Heaton
    35 Post(s)
    Mileage : 140k
    Really... Never heard of it being needed for front seats....
    Its just front I'm after not rears, don't think my bench seat even has the heated pads in...
    Administrator plasma's Avatar
    On the Forum
    551 Post(s)
    Engine : 150
    Mileage : 74000
    if you have the loom under the rear armrest it just means that you've got it to the X1 and X2 plugs by the footwells but no further. which is where the additional loom then plugs into.
    Hanging Heaton
    35 Post(s)
    Mileage : 140k
    So I still may need additional wiring from the switches to the footwells?... Is there an easy way to check the front for wiring, like pins behind the switch etc?...
    On the Forum
    551 Post(s)
    Engine : 150
    Mileage : 74000
    pop out the blanks, look for plugs behind them
    to check the body loom, remove the seat plug (after disconnecting the battery and waiting a few minutes for airbag to discharge) and look at the connector, there should be an 8 pin 'block' and 5 pins would be there if you have the body loom, if not then you need extra body cabling
    Hanging Heaton
    35 Post(s)
    Mileage : 140k
    Cheers Dean, gonna check the switches now, and I'll check the seat block tomo
    Moderator paulhb's Avatar
    Wondering lonely as a cloud
    27 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    And tech 2 is not required for heated front seats only the rears.
    Hanging Heaton
    35 Post(s)
    Mileage : 140k
    Well we have pins in the switch side...
    Its a start I suppose...
    Hanging Heaton
    35 Post(s)
    Mileage : 140k
    Bad news... Guessing its the top left of the seat block that has the 5 pins?... Doesn't have them on the CDTI...
    So guys, which is easier, a custom loom or just take it from the doner car?
  1. heated front seats
    By Vectra edd in forum Electrical & ICE (including SatNav)
    Last Post: 13th January 2012, 17:58
