Results 1 to 10 of 22
Thread: My pc is poorly
    Regular Member ion's Avatar
    walsall
    Default My pc is poorly
    Hello everyone,
    I've not been on much & won't be for a few days, as above my computer has a fault & it turns out its the power supply thats shafted.
    I'm hunting around for a new one (actually my sister is!) but it's not a "normal" one so she's having to look around a bit.
    If I can get the part number off her later I'll post it on here & enlist your help in finding one if you don't mind.
    She found one for £60 which seems a bit steep so she's continuing to search.
    I can pop on here occasionally from the office but we're busy so I have little time.
    Anyway I'm off to do some work , have a great day guys n gals
    Mileage : 000
    Hope you get sorted soon Ian I was wondering where you had got to.
    £60 Have you tried Maplins, they are pretty cheap and have a great selection ...
    Power supplies shouldn't be over £20 (and that's high end) matey. What's the make and model number of the PC dude?
    [Ex]Admin Duncan's Avatar
    What is it about yours that's not 'normal' - and what power rating (watts) is your current one.
    Some of the really hi-spec ones with all the bells and whistles can cost £50-60, but a 350W low-noise one from Maplin (for instance) is £22.99.
    When I built my most recent PC, I had to spend around £50 on one to get all the connectors I needed and a high enough power rating as it needs to run several hard discs (including SCSI ones) which all take a bit of power. Maybe you're in the same boat?
    Regular Member JuzzyD's Avatar
    Jun 2006
    Somewhere...
    Could be a size/shape issue (some smaller PSU's are expensive)
    Whats the make/model of the PC?
    walsall
    Thanks guys, I know hardly anything about the insides of a pc. Ill let you know later what is different about mine.
    My sis is pretty good, she's a programmer, I'll ask her the spec & come back later or tomorrow.
    The pc is a Packard Bell, don't know the model.
    The model, and more importantly the serial number, should be found on a metal plate or sticker at the back of the unit, near to the power sockets
    I bought a replacement power pack for my laptop last year, and didn't get much change out of £80!
    Regular Member The Doc's Avatar
    'Norf Yorks.
    Most likely just a weird shape doing Packard Bell....
    Cheaper to transplant everything into a new case for £40!
    Nicking Ya Dinner.
    You get what you pay for with power supplies I'm afraid lads, if the computer is at least 3 yrs old then a cheap generic one for 20 quid will do, if you are running multi drives,lots of memory and a decent graphic card you will need something better, the power supply is the route cause of many comp crashes, if the rails don't supply enough to the machine at a steady rate then something drops out and thats blue screen time.
    I recommend you don't get anything rated less than 500w
    Antec
    Hiper
    Thermaltake
    Enermax
    These are 4 of the better ones, avoid Q-Tec ones they are ok, but when rated 550w they don't produce any more power than a 300w one, many a discussion about cheap supplies can be googled, I recommend you have a read before you buy. hth.
  1. My poorly car is going in I can't take it no more
    By pipamish in forum Suspension, Wheels & Brakes
    Last Post: 16th February 2013, 10:27
  2. Car is poorly :(
    By sjk in forum Vectra C / Signum Troubleshooting
    Last Post: 16th December 2010, 13:58
  3. Is it poorly?....
    By bobby-tupper in forum Vectra C / Signum Car Chat
    Last Post: 15th December 2008, 14:22
  4. car is poorly
    By andy.l in forum Vectra C / Signum Car Chat
    Last Post: 18th June 2008, 09:24
  5. Poorly
    By Adamant in forum Vectra C / Signum Car Chat
    Last Post: 7th April 2006, 15:39
