Thread: Power steering level sensor
    Feb 2006
    leicestershire
    Default Power steering level sensor
    Just had the power steering faulty symbol come on the dash , had it plugged in at a mates and it sez power steering fluid level low. Well checked the fluid ,once id found that it was hidden under the wing and its full. A quick google comes up with they were loads of trouble and later models never had it , it looks to be a ***** to get at so can i just short out the switch at the plug , or do i leave it open circuit or what ? Had the car ten years now ,Elite model with everything on it i.e early one , and this is the first thing to go wrong with it ,****** rubbish,,,lol
    You can actually access the sensor in the narrow gap between the headlamp and the top of the Power Steering Pump, unscrew and remove
    If you cannot source a working second hand one, then simply TECH2 and program to ignore the sensor
    Feb 2006
    leicestershire
    Does it just unscrew i.e a thread or is it like a bayonet fitting i.e half a turn and pull it ,,,oooh err misses
    Mine unscrewed
    On the first attempt I removed the edge of the bumper, but noticed on inspection I could actually see it in the gap
    On the second attempt I found I was able to rotate the cap and remove it
    I assume this was so that during servicing you can unscrew, push to the side, insert a pipe and syphon 200ml to topup, then screw the cap back on, all without having to remove the edge of the bumper
  1. Power Steering Problem Pump/Sensor
    By Jimbob SXI in forum Suspension, Wheels & Brakes
    Last Post: 31st March 2017, 09:34
  2. Replies: 17
    Last Post: 11th March 2015, 00:55
  3. How to check Power Steering Fluid level?!?!
    By jrwilshire2003 in forum Vectra C / Signum Troubleshooting
    Last Post: 7th January 2014, 19:14
  4. Power Steering Fluid Sensor
    By JusSRi in forum Suspension, Wheels & Brakes
    Last Post: 12th August 2012, 21:02
  5. Power steering rack.Leaking.How do i check level/Top up ?
    By Dobs in forum Suspension, Wheels & Brakes
    Last Post: 25th January 2011, 00:33
vectra power steering level
