Right,
My turbo has for some inexplicable reason bit the dust.
Car 1.9 120bhp CDTi 88K - Engine rebuild 30-40k ago after hydraulic locking in flood.
Noticed turbo getting noiser recently, assumed age. Engine started using oil to the point the oil light would flicker om 1st thing then it'd be topped up.
Also noticed I'd sometimes get immense blue smoke for the 1st few mins on start up OCCASIONALLY then it clears but most times none at all. Mainly if stood a few days or on tickover for a while (deicing etc) or if ruturned to when the engine is hot (and the oil thin!) and restarted.
Mrs complained of a noise yesterday, drove it today. Checked oil before setting off and ok. Put my foot down, horrible noise kicks in and oil light comes on momentarily.
Whines and grinds as the boost builds and sounds like the bearings have gone when spools up at 2.5 - 3k rpm. Turn the engine off and theres a lovely 'spinning top' whine as it spools down! Distinct lack of power too.
Accept I have to change the turbo, but what worries me is the oil light coming on (blocked oil feed?) and the fact I've seen a puff of blue smoke around here (see pic)
Which I guess could be a blocked turbo pipe or worse, the head gasket again!
I have no worries putting a new turbo on it but given the fact the engines been rebuilt once, there's a mysterious puff of blue smoke (head gasket, blocked egr cooler???), an oil feed pipe may be blocked etc, I'm thinking about getting an exchange engine.
In the meantime, can I disconnect the turbo so I can use it sluggishly about the place for now???
Anyone reccomend anywhere around DY6 - Dudley?
Cheers and thanks in advance, Si
