Thread: spigot rings
    Regular Member decks's Avatar
    Apr 2008
    nothern ireland
    Vehicle : 2.0t btcc
    Default spigot rings
    i got a new set of team dynamics 18 inch offset is 45 and pcd is 110 they have come with plastic spigot rings do i need to fit them or would they be ok without them.
    lanark
    6 Post(s)
    Year : 2017
    i wouldnt advise running without them
    Apr 2008
    nothern ireland
    Vehicle : 2.0t btcc
    just wondering as they are 110 vauxhall fit, or would et 45 offset require them.
    Regular Member Ziggy's Avatar
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    they are for the bore. which being aftermarket wheels will be larger then standard.
    Dec 2011
    Seaham
    Fit and forget, it helps to centre the wheels onto the hubs.
    Regular Member Keif's Avatar
    In the Garage
    Quote Originally Posted by Ben50n View Post
    They don't just help, they actually centre the wheel on the hub.
    If you fit your wheels without them, you'll bounce down the road, have severe steering wheel wobble and handling would be appaling.
    If your wheel doesn't directly locate on the centre hub spigot, you MUST fit them.
    Apr 2008
    nothern ireland
    Vehicle : 2.0t btcc
    just been checking the new alloys and three are et 45 and one is et 35 strange, the spigot rings fits perfect in all the alloys, will the different et setting make any differance
    In the Garage
    The et35 wheel will sit out further then the et45.
    Personally I wouldn't run them with different offsets.
    Apr 2008
    nothern ireland
    Vehicle : 2.0t btcc
    would it cause any problems other than sticking out a bit more than the rest, i will put the odd one on the back
  1. Spacers, spigot rings, alloys.
    By Lordish in forum Suspension, Wheels & Brakes
    Last Post: 25th February 2013, 21:40
  2. what rings?
    By *enery* in forum Electrical & ICE (including SatNav)
    Last Post: 20th August 2012, 16:43
  3. how much did your spigot rings and bolts cost?
    By hoochydady in forum Suspension, Wheels & Brakes
    Last Post: 21st April 2011, 14:50
  4. Spigot Ring Size
    By redraptor_141 in forum Vectra C / Signum Car Chat
    Last Post: 18th August 2009, 07:37
  5. Hub Rings
    By rushy in forum General Chat
    Last Post: 27th April 2007, 21:35
