Results 1 to 10 of 16
Thread: Door mirror glass detached
    Regular Member ph67's Avatar
    Northamptonshire
    Default Door mirror glass detached
    Looked in the passenger side mirror this morning on the way to work to see it hanging off - just managed to stop and take it off completely before it fell off completely. It's only the glass that's come off, the black backing material is still in the housing.
    Question is - what do I stick the glass back on with? - the car is a Vectra Sri 55 plate so there is a heating element in the housing behind the black backing so I need something that isn't going to be affected by the heating element - do I use superglue, double sided sticky tape or some other glue? Anyone got any advice please as I guess it will need to be able to flex a little bit with cold/hot temperature changes over the year.....
    Nov 2010
    East Midlands
    8 Post(s)
    Trim : design
    I use Screwfix black silicone - couple of quid for a big tube and has held mine and others I have done for a couple of years now - http://www.screwfix.com/p/no-nonsens...ck-310ml/81712
    VXR where are you now
    16 Post(s)
    Vehicle : Nissan GT-R R35 Vectra XP2 CDTI
    Trim : Nissan GT-R R35
    Engine : 3.8 twin turbo 700hp
    Year : 2010
    A strong glue will do bud I've done 2 now with no problems
    13 Post(s)
    Despite some people using superglue, it's not advisable as its not flexible.
    You need something flexible like a silicone adhesive or evo-stick impact adhesive.
    East Kilbride
    Engine : 3.2 v6
    Mileage : 110,000
    Do not use superglue, It does not like damp or changes in temperature. I used strong double sided tape along time ago and still holding yet.
    3.2 v6 Signum and loving it 😁
    Jul 2011
    teesside
    Engine : Z18XER
    funnily enough, I washing car on sunday and when cleaning glass the eact same thing happened to me. just used some white silicone sealant (used white as it was already opened from a job done couple weeks ago) and it seems to have done the trick.
    Regular Member daddyjay's Avatar
    Jan 2010
    poole
    Vehicle : vectra facelift
    Trim : sri
    Engine : z20net 2oltr turbo
    Year : 57
    Mileage : 38200
    had to stick both mine back today as driving down the road and they started flapping around.
    Regular Member azacbr6's Avatar
    Dec 2010
    chesterfield
    I used impact adhesive, very thin layer is flexible and will enable the electrics to work, silicone adhesive does the same job.
    Nov 2010
    East Midlands
    8 Post(s)
    Trim : design
    Quote Originally Posted by smoggie View Post
    White will do the job fine - I only suggest black as it doesn't show up so much if it squeezes out a bit
    Regular Member tonci26's Avatar
    Apr 2011
    belgrade
    Vehicle : vectra c gts
    Engine : 1.8 petrol and lpg
    Mileage : 169000 km
    use the 3M VHB tape it is great for anything and is double sieded
  1. door mirror glass
    By markmac21 in forum Bodywork & Interior
    Last Post: 1st June 2012, 20:58
  2. Door mirror glass
    By ed taylor in forum Bodywork & Interior
    Last Post: 30th May 2010, 15:29
  3. Door mirror glass
    By victor in forum Bodywork & Interior
    Last Post: 7th November 2008, 20:03
