Thread: Upgrade advise
    Jan 2013
    Newbury
    Default Upgrade advise
    Hi guys just wondering if I change the exhaust on my facelift sri turbo with grey injectors and td04 what tuning stage can I got to ? Would I be able to jump to stage 3 or does this involve more things changed ?
    Thanks in advance
    Regular Member beat275's Avatar
    Aug 2011
    Newcastle West Denton
    Vehicle : Hatch
    Trim : SRI
    Engine : 2.0T
    Mileage : 90000
    Do you already have the TD04 and gray injectors? If so change the exhaust and you should jump straight to stage 3 after a map
    Jan 2013
    Newbury
    Yes I do got a 57 reg and it's got all those already just need a exhaust then
    Regular Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    12 Post(s)
    Vehicle : Insignia
    Engine : 1.6T SIDI Petrol
    it will probably be the TD04L11T and the denso 381cc injectors.. it will be good for tuning but if you modified that turbo you will have much more fun.. It can very easily be modified from an 11 into a 14 giving it a decent size compressor to then tune to..
    A sports exhaust is part of any tuning stage tbh but quality and performance depends on who makes it and how much you spend.. Its always best to do exhausts in the earlier stages of tuning to get the best out of the later stages which get significantly more expensive..
    Jan 2013
    Newbury
    I'm a tech for a Mercedes dealer so getting dirty isn't a problem where would I get the parts to do the turbo ? And how easy is it to do ?
    Jun 2009
    South Coast
    12 Post(s)
    Vehicle : Insignia
    thats the tricky bit..... you can send it off to CRTurbo down in the New Milton who will fit the bigger 14t compressor wheel and mill out our compressor housing or fit a bigger one one for you.. Now stripping a turbo down is easy enough but whenever a compressor or turbine wheel is changed then the cartridge needs to be rebalanced and thats the bit you can do at home..
    tbh the easiest way is to send them the whole turbo, they will have it back to you soon enough.. give them, a call and speak to Craig, he knows what he is talking about.
    Now it if you have the time you can always order a 14T wheel yourself and fit it then just send the chra itself off to be balanced but am not sure if the compressor housing is identical inside.. if it needs milling then its best they do it..
    or you buy the complete 14t upgrade kit from ebay but beware of cheap chinese copies
    Jan 2013
    Newbury
    Thanks seen some 16t upgrades but was only looking on phone so will have to look on laptop
    Jan 2013
    Newbury
    Also what exhaust do you guys recommend was thinking either cobra sport or scorpion
    Aug 2011
    Vehicle : Hatch
    Trim : SRI
    Engine : 2.0T
    Mileage : 90000
    I have a scorpion exhaust. It's a great bit of kit. Cat back. If you were to get the 14t neo bros sell them for 295 plus vat. Brand new
  1. upgrade the 314mm to vxr set up or upgrade the rears?????
    By rob warrington in forum Handling & Braking
    Last Post: 24th September 2012, 09:26
  2. advise please
    By steve66 in forum Vectra C / Signum Car Chat
    Last Post: 5th October 2010, 20:37
  3. MOT advise pls
    By yadziyad in forum General Chat
    Last Post: 6th January 2010, 05:08
  4. some advise please
    By jaysvectras in forum Vectra C / Signum Car Chat
    Last Post: 19th June 2009, 21:48
  5. Please Advise
    By Amo the Dark Prince in forum Vectra C / Signum Troubleshooting
    Last Post: 12th April 2008, 08:17
