Results 1 to 3 of 3
Thread: z20 net timing up help needed!
    Sep 2012
    cheshire
    Default z20 net timing up help needed!
    iv changed the tensioner on the balance chain and thought id lined everything up right, started the car and engine warning and fault code "mulitple engine missfire" came up so iv stripped it back down and thought it was 1 tooth out on the chain. iv taken the chain off and set it up with the markings on the sprockets, spun it on the crank and spun and spun and spun at least 12times and its lined back up 1 tooth out again, so i removed, set up again and spun and it did the same. am i missing something here or is this how it goes? how many times shud the crank be spun before the balance chain lines itself back up with the timing chain? sorry for long post! any help greatly apriciated
    Regular Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    12 Post(s)
    Vehicle : Insignia
    Engine : 1.6T SIDI Petrol
    so you set the balance shaft marks and timed up the balance chain before setting up the timing chain itself and all the chain guides and tensioners are new?
    Sep 2012
    cheshire
    No just changed the tensioner and built it back up, the timing chain was lined up and the other chain was just left where it was while i changed the tensioner so i presumed id slipped a tooth anddidnt realise and built it back up. Now iv stripped it back down to check it over and start over again with it
  1. Z19DTH Timing tool Needed ASAP
    By pattz123 in forum Engine & Drivetrain
    Last Post: 7th January 2013, 15:22
  2. anyway to do the timing belt without timing tool
    Last Post: 15th December 2012, 18:47
  3. Replies: 29
    Last Post: 25th July 2012, 22:52
  4. Help - Z32SE timing advice needed
    By mammix2 in forum Vectra C / Signum Car Chat
    Last Post: 16th March 2010, 12:56
z20net timing settings
