Results 1 to 10 of 13
Thread: Over tightened sump plug ... What to do?!
    Jun 2007
    Kidderminster, West Midlands
    Vehicle : Vauxhall Vectra
    Engine : Z30DT
    Mileage : 65905
    Default Over tightened sump plug ... What to do?!
    Hello,
    I've come to do a half year oil chance on my vectra and have noticed the last garage have made a right hash of everything.
    Thr fuel pump clip has been snapped so the plug is just pushed in and now I have a over tightened sump plug which I can't get out!
    Any advice on what to do?
    Is it worth just fitting a new sump?
    Any help would be great.
    Thanks.
    Regular Member azacbr6's Avatar
    Dec 2010
    chesterfield
    Is the plug ok? is it rounded off? or is it just tight?
    Jun 2007
    Engine : Z30DT
    Mileage : 65905
    Quote Originally Posted by azacbr6 View Post
    Unfortunately it looks rather rounded off! :-(
    Dec 2010
    chesterfield
    there are things you could do, like welding a bolt head to it to get a spanner on it (need welding tackle..etc), but I think it's best to take it to a garage, preferably a different garage, it shouldn't take them long to get it off and it'll be cheap I am sure.
    Sep 2012
    expat Lancashire lad in the Midlands
    Engine : 3.2
    You'll need to check the sump itself to make sure the threads haven't been ****ed cos of the overtightening. Are they aluminium sumps? I had to replace the sump on my Bora cos of overtightening, but it turned out to be a blessing in diguise as I could get rid of all the crud that sits on the sump pan.
    Nov 2010
    East Midlands
    8 Post(s)
    Trim : design
    As soon as I got my Vectra I serviced it - took the sump plug out (with difficulty), bought a new one and welded a bolt head onto it - never had a problem since removing it. I would think replacing the sump is a last resort - try tapping it with a chisel (not too sharp) and it should free off - try warming the plug and surrounding sump with some gentle heat - the plug and the alloy sump should expand at slightly different rates and may help releasing the plug. I would think its unlikely the thread in the sump will be damaged unless it has been cross threaded and even then you could look at having it helicoiled. Good luck with it.
    Sep 2012
    Engine : 3.2
    The sump on the bora was pretty cheap and dead easy to replace you see.
    Jan 2012
    Silverstone village
    Let me know how you get on, I was due to do a service 3 months ago , but found a similar situation not tackled mine yet as its too cold to be lying under the car.
    I have bought a replacement plug and have the oil and filter read, think I will be going with the chisel and hammer, as the head it tottally mashed a flat has been filed on one side , may try some mole grips on it?
    VXR where are you now
    16 Post(s)
    Vehicle : Nissan GT-R R35 Vectra XP2 CDTI
    Trim : Nissan GT-R R35
    Engine : 3.8 twin turbo 700hp
    Year : 2010
    you want some of these things fella fantastic bit of kit and ive yet to find a bolt i cant remove with these
    http://www.ebay.co.uk/itm/Irwin-1050...item2c69a523a3
    Jan 2012
    Silverstone village
    I think the previous owner has "modified" the head too much on mine ,might help the OP though
  1. Spark Plug & Sump Plug Torque setting - Z18XE Engine
    By wafoo in forum Engine & Drivetrain
    Last Post: 4th June 2012, 21:15
  2. sump plug
    By boodoo warrior in forum Engine & Drivetrain
    Last Post: 11th June 2011, 14:20
  3. sump plug
    By luke.oldham in forum Engine & Drivetrain
    Last Post: 7th January 2011, 22:33
  4. Sump plug RRP?
    By mishima in forum Vectra C / Signum Car Chat
    Last Post: 25th January 2009, 21:22
  5. Sump Plug ?
    By gsxrster in forum Vectra C / Signum Car Chat
    Last Post: 21st June 2008, 14:59
