Thread: goodyear tyre recall
    Regular Member padawun's Avatar
    Sevenoaks, KENT
    confused goodyear tyre recall
    Hi people, I hope that a kind soul can answer a question for me.
    The goodyear tyre recall on nct tyres 05-R-79, what was the
    fault on the tyre that meant replacement was needed?
    I have been told that this was due to ply seperation (de-lamination),
    Has anyone got a copy of the recall notice?
    Many thanks.
    Here, there and every where!
    Just done a quick search and found this from last July if any use m8.
    Quote Originally Posted by bertxuk View Post
    Ok. Called in at my supplying dealer to get this tyre business sorted out on the way home. Had a look at the bulletin but was not allowed a copy (I'm only a customer). The code number is 05-R-79. It affects Goodyear Eagle NCT 5s with a code marked on the sidewall in the range 1605-2405 (mine is 1905). I guess that this is the week/year of manufacture. So I need all four tyres replaced. I range Vx customer services (01582 721122 spoke to someone called Suzanne Thompson) to get a case number but ended up just getting advice. I should have got a recall notice for this along with a recall for the oxygen sensor (what does that do and where is it?) under another recall ref. number viz. 05-P-78.
    Sevenoaks, KENT
    Thanks for the info, I found that thread last night after postimg, what I not been able to confirm with my local Vx dealer or Goodyear is what the actual fault on these tyres is. I replace 2 tyres prior to seeing any of these theads, now because I have disposed of the old tyres I cannot go back to Goodyear for any assistance.
    If only I had joined Vectra C a year ago!
    [Ex]Admin Duncan's Avatar
    Quote Originally Posted by padawun View Post
    Yes, that was the problem. I'm not aware of anyone having even been allowed to see the recall notice, let alone having a copy.
    That's a bummer! Without the tyres you won't be able to claim back for your new ones!
    Regular Member Paddy2bsure's Avatar
    Hertfordshire
    Goodyear are exchanging the tyres... i.e. they have to receive the old ones back from a Vauxhall dealer.
    I believe this type & size of tyre were only ever fitted to Vectra's & Signum's, therefore Goodyear did their recall via the Vauxhall dealers. You were only notified if your car was likely to have been fitted with these tyres (i.e. the dodgy batch in the middle of 2005). If you got the affected tyres elsewhere (i.e. replacements of the original tyres) they still honoured the recall - although it didn't automatically show up in their recall database for your car (unless, as I said, they were on it from new).
    Do you know 100% that your tyres were in the date range? I assume you never had any issues with the tyres themselves... so all's well that ends well (assuming you had good wear out of them?).
    Sevenoaks, KENT
    The two tyres that I replaced were always going out of balance, when removed the wear pattern was very extreme (even for my driving) on the inner edge, with ply seperation on the sholuder. I replaced the tyres from a local tyre dealer and disposed of the old carcases accordingly.
  1. Goodyear nct 17" tyre pressure
    By hinesh12 in forum Vectra C / Signum Car Chat
    Last Post: 6th January 2010, 22:20
  2. Goodyear F1 tyre
    By FIL 4822 in forum Parts for sale
    Last Post: 18th June 2009, 19:24
  3. GoodYear Tyre Question Regarding Sizes !!
    By kineticmix in forum Handling & Braking
    Last Post: 23rd May 2008, 21:59
  4. Goodyear tyre fault
    By ian_h in forum Suspension, Wheels & Brakes
    Last Post: 11th June 2007, 17:51
