Likes Likes:  1
Thread: signum SQL build
    Mar 2013
    devon
    Vehicle : signum 1.9cdti
    Trim : elite
    Engine : 1.9cdti
    Default signum SQL build
    well after years of having silly loud systems i thought it was time to have a change and build something that has abit more sound quailty so over the next cuple months i will be putting all this in my signum
    Pioneer SPH-DA100 AppRadio
    gladen 4 to 6 processor
    audiocontrol epicenter
    gladen SQL 165 DUAL components
    gladen XL 250c4 4 channel amp
    2x gladen SPL 1800c1 (will be upgraded to 3 to give me 5286rms)
    3x Ascendant Audio havoc 12s
    2x xs power d3100 batteries
    2x Silent Coat MultiLayer Bulk Pack
    Silent Coat Noise Isolator 4
    Silent Coat Noise Buffler 20
    custom front door cards to hold 2 16.5 mids
    6.8cuft ported box with false floor to mount amps with perspex cover
    custom fused distribution block in copper (like the last one i built in the picture)
    knukonceptz wiring
    battery
    heres a pic of what i had in my last car
    and heres what im building in a c2 at the moment
    North West - Assistant RO Woody's Avatar
    May 2012
    North West (Warrington)
    234 Post(s)
    Vehicle : Vectra C 3.2 Elite Estate Auto Facelifted
    Trim : Elite with loads of "Extras"
    Engine : 3.2 Z32SE
    Mileage : 94,000
    That is absolutely MENTAL Liam
    Good luck with the project fella
    Woody
    Jul 2010
    This is London baby
    Vehicle : Dodge Journey
    Trim : SXT
    Engine : 2.0Tdi (VW Engine)
    Year : 2010
    Mileage : 53000
    That is some good work there. What the box going to be tuned too, obviously not to low for sq.
    Regular Member Ozyboyross's Avatar
    Oct 2012
    Sprowston, Norwich
    6 Post(s)
    Trim : SRi XP
    Engine : 1.9 CDTi 150
    Mileage : 90k
    Awesome :-)
    Does that c2 still move? Lol
    Regular Member keith1983's Avatar
    Sheffield / Spalding
    Vehicle : Vectra 1.8 SRi
    Engine : Z18XE
    I take it you don't value your hearing?
    Regular Member Mr Owens's Avatar
    Jun 2012
    Wickford
    Trim : Sri
    Engine : 2.2 direct
    Looking good mate, the only thing I'm curios about is the size of the box, I'm assuming the measurements in your picture aren't correct as they only give you 4.5cuft without any displacement.
    I will be following this thread as I really need some inspiration to get on with my install
    Mar 2013
    devon
    Trim : elite
    Engine : 1.9cdti
    Quote Originally Posted by woodpeck View Post
    Woody
    thanks woody
    Quote Originally Posted by cliomjh 102 View Post
    thanks the tuning will be around 33hz even tho this will be a SQL setup i will also be doing competitions as i am the southwest propper droppers judge.
    Quote Originally Posted by Ozyboyross View Post
    Awesome :-)
    haha its going to be back on the road in the next cuple week so i will find out then but my saxo had just over 400kg of audio. just the tunnel with the subs in weights around 240kg
    Quote Originally Posted by keith1983 View Post
    the systems i build are low tuned systems (designed to play loud between 20-40hz) so ear damage is not much of a risk at these frequencies its the door speakers playing around 4000hz that will cause hearing damage but thast why we dont turn up the doors unless they are open when demoing at shows
    Quote Originally Posted by Mr Owens View Post
    thanks mate the box above is 5.68cuft without sub and port displacement using 18mm mdf. i have made the box a little bigger so after sub and port displacement i will have 5.6cuft with around 9.6sq:in port area but looking at funds i think i am going to build a 4th order box for a single havoc 1st untill i have the other 2 subs.
    whats plans do you have for yours?
    Jun 2012
    Wickford
    Trim : Sri
    Engine : 2.2 direct
    I have my hertz hsk 165's in running from the headunit for now but they will be run off my genesis profile 4 ultra (2x300wrms) and a jl audio w3v2d4 that I'm debating weather to build a removable ported mdf box or go down the stealth fibreglass route, that will be run from my genesis profile sub (550wrms @2ohm)
    A little more sq than my last install that was 2x kicker s12l7's in a 5cuft ported box tuned to 40hz and that was running at 142db (tested at proper droppers in Essex )
    I'm assuming your on talk audio ?
    Mar 2013
    devon
    Trim : elite
    Engine : 1.9cdti
    Mr Owens sounds like a good setup I used to have 2 genesis profile 4's great sounding amps but ended up fitting them in a T4 van running 2 10s and yeah been on talk audio for years not been on there much in the last 6 months tho.
    UPDATE: Well life has been abit crazy since i 1st got the signum so havnt had a chance todo much audio work but the C2 is working now found 1 or 2 problem biggest is the roof braking all the welds then started to peal its self away from the car but its going to a friends next week for some ott metal work and boot needs to be retrimed as the leather the customer got me was shocking.
    Back to my own build the subs and sound deaderning will be here next week i have the sub box mostly done just need to make my trim panels then i can cut the port and sub holes. the front end will be next months buy working full time now so hard getting time inbetween family and work to get anything done but i have some cool idea's that i think you guys will like. pictures of the signum will be up later.
    How the c2 is looking at the moment
    Heres a video of why the roof broke.
    East Midlands - Regional Organiser new boy's Avatar
    Nov 2010
    lincs
    94 Post(s)
    Vehicle : INSIGNIA
    Trim : SRI
    Engine : 2.0
    Year : 11
    Holly c###! ive heard and seen some wild sound systems in my max power days but ive never seen anything like that!!!!
  1. Engine Re-Build.
    By charliedub1 in forum Engine & Drivetrain
    Last Post: 4th June 2011, 23:21
  2. New PC Project - Build Log
    By Penfold101 in forum General Chat
    Last Post: 17th May 2011, 22:20
  3. Signum boot build ideas
    By signum_rob in forum Vectra C / Signum Car Chat
    Last Post: 10th January 2011, 21:25
  4. build quality
    By oldcommando in forum General Chat
    Last Post: 25th October 2009, 15:16
  5. Buy Vs build a PC?
    By wardy in forum General Chat
    Last Post: 13th September 2008, 19:38
genesis profile 4 running hertz hsk
