Results 1 to 10 of 13
Thread: replacing door speakers
    Mar 2013
    south wales
    Vehicle : Vectra C facelift
    Trim : sri
    Engine : 2.2 Direct
    Default replacing door speakers
    Im looking to replace standard speakers soon to aftermarkets that can handle a bit more power but want to keep the standard head unit. Would i get away with 2x sets of 6.5" components and no subs or would i get no bass? I dont want it realy loud but enough to cope with me turning the volume and not sounding crap?
    Regular Member ThatAudioBloke's Avatar
    Feb 2013
    Newcastle, UK
    20 Post(s)
    Engine : CDTI 150
    Mileage : 103000
    The standard head unit won't be man enough to drive aftermarket speakers. It's barely powerful enough to drive the standard speakers in all honesty (iirc a standard CD30 is about 7wRMS per channel).
    All that will happen is that you'll turn it up higher to get the speakers moving and it will end up overdriving the internal amplifier, leaving you with a horribly distorted sound.
    You really should amplify any aftermarket speakers (unless you're going for simple co-axial 2 way direct OE replacements, in which case it's a bit pointless really). Components can give bass, but if that's all you're after then you're better off with a sub.
    Mar 2013
    south wales
    Trim : sri
    Engine : 2.2 Direct
    I have the cd70 navi so didnt want to change it due to the sat nav! I want to be sble to turn it up and have a clear sound but louder than the standard speakers can cope with?
    Feb 2013
    Newcastle, UK
    20 Post(s)
    Engine : CDTI 150
    Mileage : 103000
    The radio determines how loud the sound is though, not the speakers. If you can't change the radio then you need to add an amplifier - speakers are just an output device.
    Regular Member Mr Owens's Avatar
    Jun 2012
    Wickford
    Trim : Sri
    Engine : 2.2 direct
    Either go for an amp from the standard headunit or look at some componants that have a high sensitivity rating (around 90db+) the hertz dsk range are good for headunit power but nothing will beat amplifying the speakers
    Mar 2013
    south wales
    Trim : sri
    Engine : 2.2 Direct
    ok cheers. will have a think. dont realy want to change the headunit if i can help it! so may have to live with the standard speakers!
    Dec 2010
    London
    5 Post(s)
    Vehicle : Hyundai Ioniq Hybrid
    Trim : Premium SE
    Engine : 1.6 with 32KW motor
    I've just fitted Pioneer head unit to standard speakers and the difference is amazing so i think you would be better off fitting amp to get best out of
    standard speakers. What their max output is i don't know my HU is 4 x 50w and they seem to handle that HTH
    13 Post(s)
    Quote Originally Posted by paulj View Post
    Jees!! How loud do you want it?
    I can crank my CD70 up and it's plenty loud enough without sounding distorted. Even if I crank up the bass setting to 12, the speakers can cope with it.
    Mar 2013
    south wales
    Trim : sri
    Engine : 2.2 Direct
    If i try to get a decent bit of bass out of my speakers and turn the stereo up a decnt amount it sounds terrible. Speakers cant cope with any bass at all! And mine is set and treble -1 and bass +4?
    Regular Member mickydoos's Avatar
    Aug 2009
    Crawley, West Sussex
    Quote Originally Posted by troutybrown View Post
    Don't forget MAX figures are useless, only pay attention to RMS wattage. Most headunits are about 17-25w RMS per channel
  1. For Sale: Speedo / Door Speakers / Door Tweeters & Boot Lock Mechanism
    By Woody in forum Parts for sale
    Last Post: 21st March 2013, 01:15
  2. Replacing Door Speakers
    By 798EAT in forum Vectra C / Signum Car Chat
    Last Post: 17th May 2012, 21:26
  3. Door Speakers
    By VectraElite 2.2DTi in forum Electrical & ICE (including SatNav)
    Last Post: 26th February 2011, 11:11
  4. Replacing Vectra door speakers
    By Matt8 in forum Electrical & ICE (including SatNav)
    Last Post: 12th July 2009, 13:28
  5. Door Speakers.
    By aaronfenwick in forum Electrical & ICE (including SatNav)
    Last Post: 29th March 2009, 19:51
