Thread: vec c fault code help
    Feb 2013
    darlington
    Vehicle : vectra c
    Trim : elite
    Engine : 3.2 v6
    Year : 02
    Default vec c fault code help
    well today i got change to play with my new toy
    its just as i suspected , she is broke
    i need your help guys to fix this
    this is the first check
    Uploaded with ImageShack.us
    and then i did as everyone suggests and cleared the codes and took the car for a drive
    and this is what it now lists
    the car is a 02 vectra c 3.2 elite auto
    any help at all will be greatfully received
    South east
    What are the symptoms you're seeing when you drive it? At a guess, one of those codes can be resolved by changing a foglight bulb.
    Feb 2013
    darlington
    Vehicle : vectra c
    Trim : elite
    Engine : 3.2 v6
    Year : 02
    yea that the easy one
    air bag light on
    and
    hunting idle and stalls on first start now after clearing codes
    only other symptom is drinking fuel 12-15mpg
    no other problems noticed
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    What u done so far to servicing, parts replaced etc...
    Hunting idle? U mean sounds like its misfiring??
    South east
    He probably means the revs go up and down at idle by themselves.
    Feb 2013
    darlington
    Vehicle : vectra c
    Trim : elite
    Engine : 3.2 v6
    Year : 02
    yea revs climb up to 1500 then drop back to about 800 then climb again
    ive done the following
    full service
    replaced both minicats , main cat and rest of the exhaust system (new gaskets used aswell)
    as for the air bag light
    i swapped the interior from cream leather to black sri seats etc
    Jun 2011
    brum
    B1325 03 is a low voltage from the battery i think. Could be caused by a short on the power supply wires to one of many modules, but could also just be a bad battery. Maybe get it tested to see if your battery is fudged? Or borrow a working one.
    Feb 2013
    darlington
    Vehicle : vectra c
    Trim : elite
    Engine : 3.2 v6
    Year : 02
    would that come up because the engine was not running when i did the test?
    ill test the battery in the morning to see what the voltage is dropping too
    Feb 2013
    darlington
    Vehicle : vectra c
    Trim : elite
    Engine : 3.2 v6
    Year : 02
    battery voltage was 12.28 and running 14.38
  1. p1792-71 gearbox fault code plus alarm sensor fault codes
    By stu f in forum Vectra C / Signum Car Chat
    Last Post: 13th August 2013, 21:05
  2. Fault code
    By rob2.0t in forum Engine & Drivetrain
    Last Post: 21st November 2012, 22:34
  3. Fault code help!
    By joee91 in forum Electrical & ICE (including SatNav)
    Last Post: 13th July 2012, 00:52
  4. fault code on vec c 1.8 sri please help
    By gavs-sri in forum Engine & Drivetrain
    Last Post: 10th April 2012, 21:52
  5. HELP *Fault code* HELP
    By andymcniven in forum Vectra C / Signum Troubleshooting
    Last Post: 17th March 2009, 21:30
insignia b1325-03 fault code
b1325-03 opel vectra
b1325-03 vectra c
b1325-03 code
