Thread: static shock ?
    Regular Member rickeys16v's Avatar
    N.Ireland ( Broughshane )
    Vehicle : 1.9 CDTI 150
    Trim : SRI
    Mileage : 46000
    Default static shock ?
    aarrgghhh im going mad ive had the vec for 6 years now and this last 3 days everytime i touch its like touching an electric fence odd thing is its never done it before any ideas
    Regular Member azacbr6's Avatar
    Dec 2010
    chesterfield
    It's your body that pick up the static through rubbing contact between your cloths and seats or any other movement that build up a charge on your body which then discharges when you touch the car.
    your car also create charge with respect to "ground", but will normally discharge quickly through the tyres which are electrically conductive.
    Try and keep hold of the metal of the door as you get out which will help static discharge gradually.
    Trim : SRI
    Mileage : 46000
    problem is its when i get in and out
    Regular Member Ziggy's Avatar
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    Have you changed your shoes or the mats in the car?
    I always get this on holiday when i wear flip flops
    Dec 2010
    chesterfield
    You create static on your body at home as well, so try and touch the door first with your elbow or fist which are less sensitive than fingers, and like I said when you get out with door open grab the roof with right hand and keep it there before getting your feet on the ground to lessen the shock. or you can install an anti static belt or chain attached to the car frame and touching the ground.
  1. Static in radio
    By kenp in forum Electrical & ICE (including SatNav)
    Last Post: 21st September 2012, 17:47
  2. static Revs
    By kel123 in forum Engine & Drivetrain
    Last Post: 24th February 2010, 11:33
  3. static electric
    By solorider in forum The 'Off Topic' room
    Last Post: 17th June 2009, 08:17
  4. Static Caravan HELP
    By Ste in forum The 'Off Topic' room
    Last Post: 26th May 2009, 12:36
  5. Static Shocks
    Last Post: 25th December 2007, 13:26
vectra static shock
