Thread: Fitting aftermarket headunit
    Regular Member Sanders_Signum's Avatar
    Jan 2013
    Northampton
    Engine : 1.9 Cdti
    Mileage : 93,235
    confused Fitting aftermarket headunit
    Hi when fitting new head unit do you need to do anything to the original plastic surround? My new cage fits in but extremely tight I think will be a struggle to get actual head unit in aswell?! And if it does go in will it ever come out again??? Lol
    Dec 2010
    London
    5 Post(s)
    Vehicle : Hyundai Ioniq Hybrid
    Trim : Premium SE
    Engine : 1.6 with 32KW motor
    You need to take original cage out
    Jul 2011
    UK
    Year : 06
    Whs the original cage needs to come out. Can't remember how thing there a screw and clips. U need to get a fitting kit which has a surround if it's a double din
    Jan 2013
    Northampton
    Engine : 1.9 Cdti
    Mileage : 93,235
    Yes it is a double din unit but it seems the plastic surround is attached/part of the dash where buttons attach too?
    Jan 2013
    Northampton
    Engine : 1.9 Cdti
    Mileage : 93,235
    Regular Member tonci26's Avatar
    Apr 2011
    belgrade
    Vehicle : vectra c gts
    Engine : 1.8 petrol and lpg
    Mileage : 169000 km
    I think you have to take out the cage of the factory head unit before fitting the new cage
    Jan 2013
    Northampton
    Engine : 1.9 Cdti
    Mileage : 93,235
    The cage seems to be built into dash and buttons etc attach to it?
    Regular Member ThatAudioBloke's Avatar
    Feb 2013
    Newcastle, UK
    20 Post(s)
    Engine : CDTI 150
    Mileage : 103000
    You've taken the right cage out (the black one), but it looks like your double din cage is too big. There are usually 2 types, 130mm and 110mm (if memory serves). Most of the ones supplied with aftermarket headunits are the larger ones and are useless, you really need a proper double-din fitting kit, with a 110mm cage and mounting hardware to get everything fitted up securely.
    Jan 2013
    Northampton
    Engine : 1.9 Cdti
    Mileage : 93,235
    Ok cool that makes alot more sense! I thought it was a bit too snug!! Lol thanks for the advise :-)
  1. Fed up - please help... Aftermarket double din headunit fitting
    By andyfeeny in forum Electrical & ICE (including SatNav)
    Last Post: 23rd July 2010, 19:42
  2. Aftermarket Headunit
    By mshaw in forum Electrical & ICE (including SatNav)
    Last Post: 17th November 2009, 10:28
  3. Vectra Aftermarket Headunit Help
    By jmacp in forum Electrical & ICE (including SatNav)
    Last Post: 18th May 2009, 21:35
  4. Aerial not working with aftermarket headunit
    By flyjedi in forum Electrical & ICE (including SatNav)
    Last Post: 28th June 2008, 10:08
  5. Aftermarket Headunit
    By bigdan in forum Electrical & ICE (including SatNav)
    Last Post: 19th December 2006, 21:56
fitting aftermarket headunit to vectra c
