Results 1 to 2 of 2
Thread: Stiff Clutch Pedal
    Dec 2012
    Devon
    Default Stiff Clutch Pedal
    Evening all,
    This past bank holiday Ive covered near 500 miles in the vec (1.9 8v CDTI SRI) using the cruise control, but what Ive noticed is that when the car is left in the same gear for awhile then I go to press the clutch the pedal is really stiff like a back pressure has built up on it, then if i change again it feels fine.
    Is this normal for the car? Ive never noticed this before with other cars Ive owned but they haven't had cruise control and been doing the same speed in the same gear for 100's of miles!
    The car had all filters and oil changed less than 5k ago.
    Any comments appreciated!
    Nov 2010
    Lj.si
    Same car '08 88kW 105kkm=~65kmiles. I had the same thing. After long drive in last gear with tempomat on HW, when i have to change i press clutch pedal, i noticed it is quite hard feeling.
    Few days ago the clutch release bearing start to sound with high ?sqick when the clutch pedal is pressed floor down. After realesing the pedal it is quiet. I found that on the steering column there is some oil under. Is possibile, oil is leaking somewhere, because i think the steering is softer last 2 weeks.
  1. clutch pedal really soft after new clutch
    Last Post: 3rd February 2013, 14:52
  2. Stiff pedal on 2.2 dti
    By wads187 in forum Vectra C / Signum Troubleshooting
    Last Post: 7th May 2012, 20:53
  3. Clutch pedal
    By BigWilko in forum Engine & Drivetrain
    Last Post: 9th January 2011, 08:38
  4. Clutch Pedal!!
    By andd306 in forum Vectra C / Signum Car Chat
    Last Post: 25th March 2010, 21:48
  5. Clutch pedal
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 8th July 2008, 23:53
vauxhall vectra stiff clutch pedal
stiff cluth pedal and hard to change gear vectra
Is Opel Corsa lite Clutch pedal heavy to press down
vectra c heavy clutch after long distance
vectra c clutch stiff
insignia clutch pedal heavy
vectra clutch pedal heavy
heavy corsa c clutch
corsa c clutch pedal went heavy
vectra c clutch pedal gone hard stiff
stiff clutch corsa c
clutch pedal hard to press down on vauxhall insignia
vectra clutch is hard
vauxhall corsa clutch pedal hard to press
Vauxhall stiff clutch pedal
clutch pedal seems stiff insignia
stiff clutch Vauxhall vectra
clutch Vauxhall vectra stiff release
stiff release clutch vectra
vauxhall stiff clutch
vauxhall hard clutch pedal
vectra 1.9 cdti stiif clutch pedal
stiff clutch pedal
vectra c hard clutch
vectra c clutch is hard
