Thread: Vx corsa breather hose split ????
    Nov 2009
    Warrington
    Default Vx corsa breather hose split ????
    Evening guys, ok I'm after a little but if advice please. A friend of mine has a 59 plate 1.4 corsa and has had engine warning light issues for a while, a 'mechanic mate' of hers read the codes which unfortunately I don't know at this time, but he wiped all stored codes and happy motoring for a week then light comes back on car seems to idle roughly. tonight this said 'mechanic mate ' was going to replace the 02 sensor as per the codes but for some reason now has said ( and these are his words ) the cars drinking petrol and oil like we drink water and the breather hose has split. now I'm no mechanic, but why would a split breather hose cause this??? She's going to get a new hose from vx tomoz and wants me to fit it, ok no probs I said, no I'm guessing its a simple job, as for O2 sensor he said that can wait until he finds time to do it. I'd do this too but don't you need a proper tool for changing these?? So anyone shed any light on this and also advice for O2 sensor ( easy to fit or not) and also split breather hose (again how easy to fit and would this explain using oil etc) thanks y'all
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Breather pipes splitting ate common on these.
    using high fuel could be down to O2 without looking at fuel trims hard to say
    2 mins job to fit pipe.
    quick to fit O2 sensor will need either a O2 sensor socket.
    or cut the loom an use a deep 22mm socket.
    Nov 2009
    Warrington
    Quote Originally Posted by Critch View Post
    top man again there critch, if it was my own car id have a go any day, just never like working on other peoples cars thats all, she just really needs the car on friday, so if the hose is split it will use more oil, and regarding o2 sensor, having never changed one ive heard they can be a mare to get out ?? thanks again critch
    wirral
    61 Post(s)
    Trim : Basic
    Engine : 1.9
    Theirs a small chance it may use oil if its using it a large rate it may have other problems.
    o2 on corsa is easy enough to get to mate just get it hot an it'll be sound
    Nov 2009
    Warrington
    Thanks buddy
    Nov 2009
    Warrington
    Default Link
    Just after a bit more advice here gus (sorry) I've now noticed oil leaking from this part, is the centre of the picture, it's dripping from here onto a coolant hose below. , here's the link to dw thanks http://www.detailingworld.co.uk/foru...d.php?t=302261
    wirral
    61 Post(s)
    Trim : Basic
    Engine : 1.9
    Can't see a picture mate
    Regular Member Neve'o's Avatar
    Norfolk
    Vehicle : Vectra SRi 150 Hatch
    Mileage : 69'000
    That's a very common place for an oil leak on these engines, pull the plug out it it will be full of oil, the sensor needs replacing, £10 from a motor factor/ebay or maybe around £20 from vaux.
    Nov 2009
    Warrington
    job done, want to say a massive thanks to Critch for contacting me today to help me sort this out. Fitted the new hose and thanks to Critch identified a faulty oil pressure switch also. fitted them for her tonight and all done in 10 mins and for under £16 so happy days , and a big thank you to Critch for the advice, a top man indeed ha. Cheers fella. Rob
    wirral
    61 Post(s)
    Trim : Basic
    Engine : 1.9
    No dramas mate you know where I am any time
  1. Split hose
    By s2yob in forum Engine & Drivetrain
    Last Post: 20th September 2011, 19:49
  2. turbo or split hose??
    By jsnlvxr in forum Engine & Drivetrain
    Last Post: 8th November 2010, 17:54
  3. split hose
    By SB3871 in forum Engine & Drivetrain
    Last Post: 7th July 2009, 14:46
  4. Split Turbo Hose
    By Batesie in forum Diesel Engine related
    Last Post: 22nd May 2007, 16:43
  5. split in hose
    By bentleyboy in forum Engine & Drivetrain
    Last Post: 12th October 2006, 17:54
split breather pipe
breather pipe corsa
where does a breather pipe fit on corsa engen
does o2 sensor fault cause breather hose split
why does my engine breather hose keep splitting
pipe casing split corsa
vauxhall corsa engine breather pipe whats for
opel corsa breatha pipe
vauxhall corsa engine breather pipe split
could split breather hose use more oil
corsa breather pipe split
corsa d oil breather pipe
