Thread: I opened my egr(z30dt, electrical part) pics inside.
    Jan 2013
    Finland
    Default I opened my egr(z30dt, electrical part) pics inside.
    Well, my egr said goodbye. And as I was sure the egr was/is busted, I thought let`s open it
    So I took hacksaw and randomly started sawing And quess what, you can open the egr and clean it if you want to. Theres`s these electrical surfaces to clean as you can see from the pics mine was really dirty.
    My main fault is progen contact pin (last pic). I did clue it back with superclue (yes, the electrical contact was there) and taped the egr back together. This was only for testing. But the result was amazing. My car was working like never before, no judder, no random autogear changes, pulling wonderfully etc.
    My clue snapped off, so back to the drawing board I will get it fixed. Not going to buy new egr.....yet
    But, your egr CAN BE DIRTY and not working as it should. My car didn`t have any warning messages before the snapped pin.
    Regular Member yessof's Avatar
    Jan 2008
    west yorkshire
    The part which has broken looks like a carbon brush.
    Jan 2013
    Finland
    Yes it is
    Regular Member ThatAudioBloke's Avatar
    Feb 2013
    Newcastle, UK
    20 Post(s)
    Engine : CDTI 150
    Mileage : 103000
    You need to use something like Araldite to seal it back together. Iirc it's fuel and oil resistant so should cope pretty well under the bonnet.
    Jan 2013
    Finland
    Quote Originally Posted by BoostPuppy View Post
    This thead is to show that you CAN clean your Z30DT egr. I know my ways with clue
    Feb 2013
    Newcastle, UK
    20 Post(s)
    Engine : CDTI 150
    Mileage : 103000
    Quote Originally Posted by dibar74 View Post
    It was merely a suggestion of an improved glue, as you said yours had failed. Other people may not know how to seal it back up effectively.
    It has already been discussed that the EGR Valve on the Z30DT can be removed and cleaned
    The assembly should actually come apart
    However, the EGR Valve on the Y30DT cannot be cleaned, once it has failed that is the end of it
    Jan 2013
    Finland
    ok!
  1. What am I missing? Pics inside.
    By JJ0063 in forum Electrical & ICE (including SatNav)
    Last Post: 7th January 2013, 21:22
  2. any mod suggestions (pics inside)
    By vectra_ in forum Vectra C / Signum Car Chat
    Last Post: 11th July 2010, 05:13
  3. New Baby (Pics inside)
    Last Post: 10th June 2010, 18:48
  4. My story so far - pics inside
    By tom_p_2000 in forum Vectra C / Signum Car Chat
    Last Post: 11th May 2009, 19:28
  5. Electrical part needed
    By Higgins in forum Vectra C / Signum Car Chat
    Last Post: 16th January 2006, 17:46
should the electrical part of an egr valve be in or out vectra
egr z30dt
