Results 1 to 10 of 14
Thread: Is there a problem with my injectors ???
    Oct 2012
    Ashford, Middlesex
    Default Is there a problem with my injectors ???
    These are my injector readings, injector 3 seems out and seems to get worse after about 20 secs as in the second picture.
    Regular Member justin32's Avatar
    Aug 2011
    Basingstoke
    5 Post(s)
    Vehicle : Vectra c SRI Facelift
    Trim : SRI
    Engine : 1.9 CDTI 150
    i think number 4 is out the furthest but i maybe wrong
    Oct 2012
    Ashford, Middlesex
    ok cheers for that, to be honest i dont have a clue what the figures mean or what they should be lol so if any body can explain it would be fantastic :-)
    cheers
    Aug 2011
    Basingstoke
    5 Post(s)
    Trim : SRI
    IIRC i read a post saying that anything below +4 is ok....ill have a quick search for you
    Administrator plasma's Avatar
    On the Forum
    548 Post(s)
    Engine : 150
    Mileage : 74000
    Quote Originally Posted by dontsnatch View Post
    cheers
    That is showing you how much CORRECTION the ecu is doing to the amount of diesel injected per stroke.
    if its + figure then its adding more fuel per stroke
    if its - figure then its subtracting fuel per stroke,
    ideal is 0 or as close as possible.
    no.4 is way out and could do with sorting. the others may be trying to compensate which is why some of them are out as well.
    i#ll check the max tolerance before vauxhall say they are too far out, dont think its as much as + or - 4 though, will try to find out
    Oct 2012
    Ashford, Middlesex
    Ok cheers for that info, could this be the cause of the common smokey/bad idle on a cold start ??? If so I've got a spare injector I could try to see what happens. I've got cdti 120
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    -/+ 3 is within tolerance I think so 4 would need looking at
    and going from their.
    if you have a spare worth swapping to check.
    make sure its codes in
    Oct 2012
    Ashford, Middlesex
    Ok cheers for that, at work next couple of days and expecting baby any day so mite not get the chance until next week but will let you know, thanks again for explaining and help :-)
    Aug 2011
    Basingstoke
    5 Post(s)
    Trim : SRI
    heres my injector reading i done today,ive got the 150 so dont know if they should be the same reading or not?
    On the Forum
    548 Post(s)
    Engine : 150
    Mileage : 74000
    they are looking spot on mate
  1. '06 150 injectors? Had everything else done!!
    By snare2 in forum Vectra C / Signum Troubleshooting
    Last Post: 18th November 2012, 20:27
  2. injectors
    By sandy13 in forum Vectra C / Signum Troubleshooting
    Last Post: 21st January 2012, 11:08
  3. Injectors
    By signumboy in forum Engine & Drivetrain
    Last Post: 28th September 2011, 21:23
  4. Injectors
    By leighhockey in forum Vectra C / Signum Car Chat
    Last Post: 25th September 2011, 10:49
