Thread: Vectra heater blower motor problem...ongoing!
    Mar 2013
    Essex
    Trim : club
    Engine : diesel
    Default Vectra heater blower motor problem...ongoing!
    Hi all,
    My 2004 Vectra Club CDTi is displaying all the typical signs of a knackered heater blower motor resistor, ie. the fan only works on position 4. I bought a new genuine GM resistor, fitted it, but the problem persists - only blows on position 4.
    I've noticed the fan does work in the other positions very intermittently, sometimes if I brake hard it will get it working.
    Any ideas or suggestions guys?
    Thanks in advance
    13 Post(s)
    Does the motor spin freely?
    All connections secure?
    Mar 2013
    Essex
    Trim : club
    Engine : diesel
    Motor spins freely for sure....don't know about connections. Which ones should I be checking and where are they please?
    Jan 2012
    Silverstone village
    1)Try pulling out the resistor pack and putting the fan on 4, confirm the fan runs.
    2) get a multimeter on the resistor pack and see if you get any voltage on any of the terminals from an earth in the car
    3) this will confirm if the resistors are actually getting any power.
    ps, be careful as the resistors may get hot it they are working.
    Apr 2013
    SUFFOLK
    Vehicle : VECTRA
    Trim : ENERGY
    Engine : 1900 DIESEL
    Hello from a new member
    Got the same problem ,water ingress due to a blocked drain, now heater blower only works on 4, where is the resistor thing? is it a job to get too
    13 Post(s)
    Quote Originally Posted by SNIKTOP View Post
    It's mentioned in the how2 section.
    Apr 2013
    SUFFOLK
    Vehicle : VECTRA
    Trim : ENERGY
    Thanks Big Dave much appreicated
    Regular Member tga's Avatar
    Budapest
    Vehicle : Vectra C GTS
    Engine : Z22SE
    Mileage : 287000 km
    Hi all,
    There's a bit different blower motor problem. For a few weeks, my 2003 year SRI's blower doesn't stop, not even when I pull out the key from the igniton barrel. :S The fan works fine on any position, but only helps, if I remove the fuse. Any idea? The resistor replacement didn't take any effect, the symptom constant. Every helps appriciated!
    Wigan
    Trim : Exclusive
    Engine : 1.9 CDTI
    The resistor pack does get very hot when in use. I speak from experience!
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 167340
    Quote Originally Posted by dave300776 View Post
  1. wanted heater blower motor vauxall vectra c
    By Les45 in forum Vectra C / Signum Car Chat
    Last Post: 24th May 2011, 08:21
  2. help heater blower motor
    By whitevanman in forum Vectra C / Signum Car Chat
    Last Post: 5th December 2010, 01:27
  3. Zafira Heater/blower motor
    By glenboy in forum General Chat
    Last Post: 9th June 2010, 22:01
  4. Sqeeky heater/blower motor.
    By SNODDY70 in forum Electrical & ICE (including SatNav)
    Last Post: 28th June 2009, 23:05
