Thread: Stiffer springs for a 2.0 DTI estate
    Mar 2013
    Scotland, North East
    Vehicle : Saab 9-3 (Vectra C in disguise)
    Trim : Linear Sport
    Engine : 1.9 TiD 150
    Default Stiffer springs for a 2.0 DTI estate
    So both front shocks were leaking, rear shocks look newish, so ordered a pair of monroe reflex shocks for the front, springs look ok for the moment however in the future (when funds allow) I'm considering swapping whats on it for something stiffer but not teeth shatteringly harsh and stock ride height (use it for work and a lot of speedbumps and winter snow around here so reasonable clearance is required.) as currently I find the suspension too soft and the handling therefore...vague.
    Previous motor was a Corolla that was as bad, until I swapped the shocks and springs for new KYB kit and then it was pretty spot on, stiff but still enough give over potholes etc to not be bone jarring.
    Thoughts?
    Full Member Z80's Avatar
    Apr 2008
    Noumea
    16 Post(s)
    Vehicle : Opel Vectra GTS
    Trim : Elegance
    Engine : 2.2 DTi 16V
    Mileage : 75 000
    3.0 V6 CDTi SRi springs. Will probably sit the car a bit higher than DTi SR ones and hopefully be stiffer (I've got problem with the car crouching in slopes and turns, and the front spoiler lip scraping on ramps). Going to try the 3.0 springs Sebastian just sent me.
    Mar 2013
    Trim : Linear Sport
    Mine currently looks low in the front, but high in the rear...so something isn't right somewhere...
    New front shocks might improve that, but could well be someone dropped it in the past and someone then fitted standard springs to the rear again but didn't change the fronts.
    I needed a bigger car for work and home life, but I miss decently stiff suspension.....vectra is like driving a couch.....to the point its disconcerting at times.
    Mar 2013
    Trim : Linear Sport
    I'd take a minor drop say 10 to 20mm, but nothing like 40 -60mm, Someone did that to the corolla before I got it (and changed it back to stock) and I'm sure I scraped the exhaust and the cat on several speed bumps....plus any potholes were spine shattering....
    Apr 2008
    Noumea
    16 Post(s)
    Trim : Elegance
    Mileage : 75 000
    Quote Originally Posted by MrF View Post
    Same here. DTi engines are heavy and SRi springs stiffness seems clearly underrated for my engine.
    On the other hand, measuring the wheel arches weights contradict this feeling, but measuring under the chassis confirms it... Something to do with the car design, IMHO.
    If you have an Estate, you also have musch stiffer springs to the rear to cope with heavier load... But the car is rarely fully loaded, giving it a bent towards the front stance !
    Standard suspension is known to be soft, but the SRi one is OK. Except that having fitted 8" wide rims ET35, The front suspension has to bear more torque than intended, making it softer. That's why I'm going to try stiffer, though not lowering, springs. SRi-like of course, not standard.
  1. how much stiffer ??
    By bembo449 in forum Vectra C / Signum Car Chat
    Last Post: 7th July 2011, 12:35
  2. Stiffer rear springs for Dti
    By Jonsey in forum Handling & Braking
    Last Post: 27th April 2011, 20:47
  3. Steering Stiffer to turn to the right than left.
    Last Post: 22nd February 2011, 20:52
  4. 2.0 T SRi springs 07 Estate
    By blue estate in forum Parts for sale
    Last Post: 24th February 2010, 23:34
