Thread: 2.0 TDI temp sender plug
    Regular Member andy jack's Avatar
    Mar 2013
    manchester
    Trim : Club
    Engine : 2.0 DTI
    Default 2.0 TDI temp sender plug
    This should be easy enough. How do you remove the above? I simply cant work it out and don't want to potentially damage it with excess force. I cant find an image of one at the moment but will take a photo tomorrow if I still cant find one.
    I have found an image here in brianjamesreed's Theromostat How 2. I hope he does not mind if I use his image?
    Temp sender plug is top right of center in the image below.
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Push plug inwards slightly then press down on tab.
    Mar 2013
    manchester
    Trim : Club
    Engine : 2.0 DTI
    Thanks for the reply Critch. I feel like a right idiot for having to ask in the first place. It is not as if I am a kid or a stranger to working on cars. Yet despite all that I am still struggling. When you say "push plug inwards" is that downwards towards the sender? And "press down on the tab" do you mean squeeze it inwards or literally downwards towards the sender?
    I can't believe a plug is giving me so much grief but I just can't get my head round how it works.
    wirral
    61 Post(s)
    Trim : Basic
    Engine : 1.9
    Yeah literally push it inwards towards the sender an then squeeze the tab.
    it will probably go just same with pair of long nose pliers
    i know your feeling tho mate. Sonetimes ya can be like wtf. And someone else just comes along and does it.
    can you get a closer pic tho. Just take make sure I'm not giving you dud info
  1. Un-plugging coolant temp sender plug
    By chaz in forum Engine & Drivetrain
    Last Post: 1st March 2011, 22:12
  2. Where is the coolant temp sensor/sender on a 3.2 Petrol?
    By marcdale in forum Engine & Drivetrain
    Last Post: 1st June 2009, 11:08
  3. RE-External temp sender fault
    By Charlie miller in forum Electrical & ICE (including SatNav)
    Last Post: 30th December 2008, 23:52
  4. Help with Temp Sender Sensor
    By kryton01 in forum Engine & Drivetrain
    Last Post: 4th December 2008, 11:12
