Thread: Windy Rear End?
    Jan 2013
    Ipswich
    Default Windy Rear End?
    The Vectra, not myself.
    Basically....I'm getting a load of wind noise 'cooooo'ing through from the rear somewhere and it's doing my head in lol.
    Is this normal? Is there a common fault of a bung falling out of anything? I even wondered if its the shape of the alloys or something (Design 16s)....
    I had a huge rusty hole in the rear quarter of my last car and its the same irriting noise lol....gets really loud at 70+ too. Any ideas lol?
    Tom
    New Member NedVincent's Avatar
    Mar 2013
    Mid Norfolk
    Trim : SRI
    Engine : 1.8 VVT
    Mileage : 76 000
    I find my current tyres give terrible road noise! Cant wait to replace them. Might be the same?
    VXR where are you now
    16 Post(s)
    Vehicle : Nissan GT-R R35 Vectra XP2 CDTI
    Trim : Nissan GT-R R35
    Engine : 3.8 twin turbo 700hp
    Year : 2010
    Check all your door seals bud and around the tail gate... ive even adjusted the door catches slightly to make the doors shut tighter.... But most noises from the rear end are tyre related some tyres are worse then others..
    Jan 2013
    Ipswich
    Hmm, I have brand new Uniroyals on the back (not rainsports, the ones with the less cool tread pattern lol)...wonder if its them causing it then, anyone else have issues with those tyres?
    I'd like to know for sure if possible just incase its something worse (did wonder if it was a wheel bearing failing :/ )...
    I've checked around the door and boot seals and cant see any obvious issues with them. I've also driven with a heavy load and the rear seats down today and the noise was the same, not louder at all....so that to me says its not bearings as the weight would make a difference and it cant be anything to do with the boot....
    Wirral, UK
    Vehicle : Mokka
    Trim : SE - Orange Rock 's !!
    Engine : 1.7CDTi
    I have rear noise too. And 16" design wheels. I have a problem with the rear door windows I need to investigate, if I use a hose pipe or pressure washer on the windows water gets inside the window from the top seal at the back end of the window. So this could be where the noise is coming from when driving. I intend to get some light square foam, no adhesive, and push it inside the seals at the top of the window to see if that makes a difference.
    Jan 2013
    Ipswich
    Ah ok, hmm maybe thats a possibility then. Cant say I noticed any water coming in (but Ive only pressure washed it once so far) but could be the same issue.
  1. A Bit windy
    By david-bell in forum General Chat
    Last Post: 3rd January 2012, 23:31
  2. Windy weather
    By FIL 4822 in forum General Chat
    Last Post: 30th May 2011, 15:34
  3. few pics i took on a wet and windy day in west kirkby
    By jonny p in forum Quick Photo Album
    Last Post: 5th August 2009, 06:40
  4. Hello from the windy North East
    By vxvirgin in forum Introduce yourself.
    Last Post: 1st February 2008, 08:49
  5. From Wetta Pod to Windy Pod
    By nutron in forum Vectra C / Signum Car Chat
    Last Post: 7th September 2006, 12:37
