Thread: rear washer on vectra c hatch back
    northwest
    Default rear washer on vectra c hatch back
    the rear washer has stopped working but the pump still works...i presume the pipe is blocked...can anyone tell me if the pipe is under the carpets or in the roof lining....cheer's.....
    Regular Member Ozyboyross's Avatar
    Oct 2012
    Sprowston, Norwich
    6 Post(s)
    Trim : SRi XP
    Engine : 1.9 CDTi 150
    Mileage : 90k
    Mine never worked since I got it untill I got a sewing needle and genty stuck it down the nozzle... I could feel like a gritty feeling while doing it and now it works again!
    Could be worth a try :-)
    northwest
    hi....yeh tried needle in the nozzle but was clear.....not sure wether blocked or kinked with opening and shutting hatch...
    northwest
    was working last week but ran out of water......after refilling the bottle it stopped working...
    Regular Member LGaffer's Avatar
    Dec 2012
    Castleford
    5 Post(s)
    Vehicle : Vectra C Preface
    Trim : SRI
    Engine : 1.9 cdti 150
    The pipe goes up over the passenger side of the headliner if i remember correctly. Mine stopped working too just after i ran out of screen wash. I was told if you remove jet from the ariel base and remove pipe from washer bottle and send a jet of air through with a compressor it should clear the blockage. Haven't got round to it as yet but if you try it let me know how you get on.
    Hanging Heaton
    26 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 140k
    Anyone know where the rear pipe runs into the car, or the exact route from bottle to the rear as I want to remove it...
    Also which side off the pump is the rear one? Looking at the pump attatched to the bottle, is it the one facing the engine or the one facing out to the N/S?
    http://www.euroautomotive.co.uk/imag...26%20small.jpg
    Regular Member ThatAudioBloke's Avatar
    Feb 2013
    Newcastle, UK
    20 Post(s)
    Engine : CDTI 150
    Mileage : 103000
    Quote Originally Posted by vec22direct View Post
    Probably some washer bottle slime has bunged up the filter - might be worth pulling the filter out of the bottle and giving it the once over.
    May 2012
    county durham
    Mileage : 145k
    the rear washer stopped working on my brothers old SRi direct ( 04 plate ) and the pipe had popped out of a push fit connector above the roof lining , above rear left door .
  1. Quick question - Rear Washer Jet Adjustment (08 Plate Hatch)
    By king_chris in forum Vectra C / Signum Troubleshooting
    Last Post: 8th March 2010, 02:02
  2. Rear hatch vectra c
    By brains in forum Bodywork & Interior
    Last Post: 21st February 2009, 16:09
