Results 1 to 2 of 2
Thread: Faulty O/S front indicator?
    Jan 2013
    Hinckley
    Default Faulty O/S front indicator?
    Hi there guys,
    I have a 1.9cdti signum Elite 05 plate and have had nothing but problems with it (but love the car!!)
    The most recent problem is my O/S front indicator. It does not work and has a rapid click as it is turned on, it also indicates the fault on my computer. I assumed it was a faulty bulb but after going to the trouble of swapping it, found the light still didnt turn on and the bulb i removed was still fine.
    If you have any ideas of how i can get this working or where in the middlands i can get it fixed i would be amazingly happy!!
    Jimbo
    Dec 2011
    Seaham
    Try cleaning the contacts in the bulb holder.
    Check that you are getting power to the front indicator with a test bulb, then if no power trace fault back, p[ossibly a broken wire or dirty connector.
  1. Left indicator flashing fast, front indicator not working
    By Hummelshøj in forum Electrical & ICE (including SatNav)
    Last Post: 7th August 2017, 14:42
  2. Faulty front wipers / washer
    By matt_vec2007 in forum Electrical & ICE (including SatNav)
    Last Post: 11th November 2011, 10:12
  3. Vectra C Facelift, faulty front fog lights glass
    By 150_SRI in forum Vectra C / Signum Car Chat
    Last Post: 1st December 2010, 11:44
  4. Front OS indicator issue
    By CowFish in forum Electrical & ICE (including SatNav)
    Last Post: 28th October 2009, 08:43
