Thread: Still getting error P1125
    Regular Member Slammedorion's Avatar
    Mar 2012
    cheshire
    11 Post(s)
    Default Still getting error P1125
    Still getting error P1125 on my07 cdti 120.
    Throttle actuator malfunction.
    I've had the throttle body apart and inspected the circuit board, was full of oil but looked fine after a clean.
    Is P1125 a fault with my throttle body then?
    If so I'm just gonna replace it with a new'en from ECP. About £180 quid.
    Aslong as it fixes it I'm not to bothered.
    Jan 2012
    suffolk
    Hi Have you checked soldered joints with magnifying glass look here http://www.vectra-c.com/forum/showth...45#post1338145 Shaun.
    Mar 2012
    cheshire
    11 Post(s)
    Just check joints by eye tbh, Mines filling with oil too... Is P1125 a fault with the throttle body then?
    Sep 2012
    Teesside
    had this fault, I just changed the throttle body actuator just got one from the scrappy, cleared the code. its never been back.
    Slammedorion did you clear the code after cleaning it.
    Mar 2012
    cheshire
    11 Post(s)
    Yes keep clearing this fault, just every few weeks it has a mishap, pressuming the throttle body actuator is the throttle body?
    Jan 2012
    suffolk
    The black box with the circuit board in is the actuator, the circuit board on early vectra's suffer with dry solder joints giving the p1125 code, mine was really hard to see the dry joints without a spot light and magnifying glass. Shaun.
  1. code p1125 (61)
    By the-wizard in forum Engine & Drivetrain
    Last Post: 8th July 2011, 18:33
  2. Code p1125
    By collyb in forum Engine & Drivetrain
    Last Post: 23rd April 2011, 23:46
  3. Error code p1125 throttle actuator...
    By CADT674250 in forum Engine & Drivetrain
    Last Post: 18th January 2011, 19:48
  4. P1125-0f
    By slipperysam1984 in forum Engine & Drivetrain
    Last Post: 13th December 2009, 20:29
vectra z19dt p1125 www.vectra-c.com
z19dt p1125
vectra cdti p1125 www.vectra-c.com
vectra-c.com z19dt p1125
