Thread: vectra c 52 1.8 cam sensor testing?
    Feb 2013
    Northants
    Vehicle : Vectra c
    Trim : Ls
    Engine : 1.8
    Year : 52
    Default vectra c 52 1.8 cam sensor testing?
    hi,
    if i unplug the cam sensor it dosent change the idle.
    i want to test it, it is hall effect and therfore 3 wire.
    the plug from the ecu with ign on but not running has +5v on both outer terminals and the center is ground? is this right i would of expected a pos a neg and a sensor wire?
    thanks
    barks
    Feb 2013
    Northants
    Vehicle : Vectra c
    Trim : Ls
    Engine : 1.8
    Year : 52
    right, tracing the wires i got
    1 - sensor
    2- earth
    3 - +5v
    im getting a fixed 2.5v on pin 1 whilst eng is idling? this isnt right is it?
    thanks
    Feb 2013
    Northants
    Vehicle : Vectra c
    Trim : Ls
    Engine : 1.8
    Year : 52
    anyone?? before i have to buy one??
    Feb 2013
    Northants
    Vehicle : Vectra c
    Trim : Ls
    Engine : 1.8
    Year : 52
    just noticed i i unplug the crank sensor it dosent change either?
    thanks
    Feb 2011
    Selby
    What are you measuring it with, a voltmeter? It's a steady stream of pulses, one for every rotation of the camshaft. You'll need an oscilloscope to see them, as there will be about 5 pulses a second at idle (camshaft turns once for every two crankshaft rotations). All you'll see with a voltmeter is an average value - ie 2.5V.
    If you're getting cam sensor failure codes (and 4000rpm rev limit), then replace the sensor with a genuine GM one. I spent months having the garage I bought the car from mucking about trying to cure that error, until I threatened to ask for a refund and they fitted a genuine sensor rather than a pattern part. The problem went away and hasn't come back in over 30,000 miles.
    Feb 2013
    Northants
    Vehicle : Vectra c
    Trim : Ls
    Engine : 1.8
    Year : 52
    Quote Originally Posted by rich r View Post
    thanks rich,
    the wire was all broke and bare so ive replaced it and its the same, i bought the crank sensor too but it just fell apart in my hands whilst fitting it!!!
    the end of it being a small black disk is now inside! does anyone think this small plastic disc will cause a problem if left in or do i get it out?
    thanks
    Regular Member triple595's Avatar
    Mar 2011
    llandrindod wells
    Symptoms of my cam sensor failing was when it gets hot it would go into limp home mode and eventually not start cost me 100 quid to fix at local dealer
  1. Sensor Testing - All Member Collaborative Spreadsheet
    By jamesmcuk in forum Vectra C / Signum Troubleshooting
    Last Post: 17th September 2012, 19:35
  2. resistance testing a MAF sensor
    By justin32 in forum Engine & Drivetrain
    Last Post: 16th November 2011, 01:36
  3. Testing a vectra gts
    By new boy in forum Vectra C / Signum Car Chat
    Last Post: 9th July 2011, 20:44
  4. Testing Camshaft sensor V6
    By vecest in forum Engine & Drivetrain
    Last Post: 7th February 2008, 14:16
  5. best looking vectra (testing)
    By yorkshireborn in forum General Chat
    Last Post: 7th May 2006, 14:52
1.8 opel vectra cam sensor omh test
where is the cam sensor on a vectra c
