Results 1 to 3 of 3
Thread: ABS warning light
    Wirral
    Default ABS warning light
    The ABS warning light on the dash stays lit after the engine has started Ive had the code read and it is C0035 - Front Left Wheel Speed Sensor Circuit High Voltage.
    Could this be a easy fix or a possible expensive headache I have tried googling an answer but no success i'm hoping someone here can help thanks.
    Feb 2013
    perthshire
    Engine : VVT
    Mileage : 37000
    Not much into car electrics, but it works similair to some machines I work on. Basically the sensor creates a voltage which is then sent to the abs module, it then decides depending on the voltage what is going on. At least I think thats what happens in cars anyway. Sounds to me like it could be a faulty sensor. Wouldnt think it would be that expensive to replace. I would however wait until someone with more experience comes along though.
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 85000
    You will need a New front NS Hub, as I dont think the ABS senors is replaceable on its own. You could always just check and see if the wire has broken, that may be repairable.
  1. Brake Light Warning Light
    By michaelangelo in forum Electrical & ICE (including SatNav)
    Last Post: 29th August 2011, 01:31
  2. Another warning light!!
    By Carl83 in forum Engine & Drivetrain
    Last Post: 10th August 2011, 15:22
  3. Oil warning light
    By Chris Tamlyn in forum Engine & Drivetrain
    Last Post: 9th March 2011, 11:54
  4. Spanner light & 3rd brake light warning?
    By simp_2.2sri in forum Electrical & ICE (including SatNav)
    Last Post: 5th December 2008, 17:32
  5. arghh side light problems warning light
    By Gregg in forum Electrical & ICE (including SatNav)
    Last Post: 11th February 2008, 21:58
