Results 1 to 10 of 19
Thread: Rear LED brake light not working
    Regular Member dodus's Avatar
    Jun 2009
    edinburgh
    Default Rear LED brake light not working
    Hi guys is it possible to remove the LED brake light in the tail gait as mine has stopped working
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    I'm sure I've read once you get past the tailgate lining, etc the unit is actually rivetted in place. If that's the case then it can always be drilled out, but obviously you'd need to look at re-securing options available to you first.
    Jun 2009
    edinburgh
    so you cant just replace the LEDs easily then?
    Jun 2009
    edinburgh
    its the light on the boot lid BTW
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Not and 'unbolt/unclip, old out, new in, clips on/bolts in' job at all, no.
    As for removing the lamp bar unit and repairing it, I've not heard/read of anyone going that far... merely fitting a replacement light bar.
    Sep 2012
    Stoke on Trent
    Engine : 1.9 CDTi 150 Z19DTH
    Hi. They are pain to remove but can be done with some drilling involved. If you take the tailgate liner off you will see the housing
    where the 3rd brake light is fitted it is sealed so there is no way of getting to the bolts securing it. If you look close at that housing you will see
    3 dots that are the places where you need to drill, once drilled the holes out you'll see the screws through them, use an allen key to undo the screws
    and it will pop out, dont try to get it out with a screw driver, useless, its just going to break.
    Hope this helps.
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    When I tinted mine it was only clipped in place when I took the boot lining off I just pushed it out.
    Sep 2012
    Stoke on Trent
    That is a bit odd, every single car we broke had to be drilled as there was no access to the 3rd brake light what so ever.
    Done one today, will take a pic in the morning.
    Full Member Z80's Avatar
    Apr 2008
    Noumea
    16 Post(s)
    Vehicle : Opel Vectra GTS
    Trim : Elegance
    Engine : 2.2 DTi 16V
    Mileage : 75 000
    Depending on your car's year, you may have to drill two holes to reach the unlocking clips.
    First remove your hatch lining and check how it looks. I should have pics too, I'll try to post them later.
    Sep 2012
    Stoke on Trent
    Here is a picture of the one I have done yesterday, I have broken loads of Vectras and
    all of the had to be drilled
  1. Brake Warning light and display error message , BUT BRAKE LIGHTS ARE WORKING FINE
    By JACKALG1 in forum Electrical & ICE (including SatNav)
    Last Post: 24th May 2013, 18:56
  2. rear fog light not working
    By keggy77 in forum Electrical & ICE (including SatNav)
    Last Post: 18th July 2012, 16:59
  3. I now have a working rear interior light
    By rob warrington in forum Electrical & ICE (including SatNav)
    Last Post: 7th January 2012, 16:55
  4. Is it right to only have one rear fog light working ?
    By muffking in forum Vectra C / Signum Car Chat
    Last Post: 29th December 2006, 15:55
rear boot lid lights on insigna not working
vectra diesel boot brake light its not working
vectra c 3rd brake light not working
third brake light not working
