Thread: no gears...........please help
    Regular Member bigdan1505's Avatar
    Nov 2012
    wrexham
    Vehicle : signum
    Trim : elite
    Engine : 1.9 cdti 150
    Mileage : 129,000
    Default no gears...........please help
    please can someone shine a light in the right direction please. i have no gears for the last couple of days ive noticed that the selector has been a bit sloppy you could stick it into gear and you could still move the stick. today ive gone to it put it in first pulled out my drive popped to shop on the way out got in the car and nothing.... nothing at all.. wont select any gear car starts up fine clutch presses in but nothin no crunchin either im a bit puzzled tbh can anyone help please cheers
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Take a look at the linkages both at the gearstick and gearbox ends... wouldn't be the first time a cable had failed or a clip popped off.
    Just hope it's that simple for you.
    Administrator plasma's Avatar
    On the Forum
    540 Post(s)
    Engine : 150
    Mileage : 74000
    As above check the cable near the gearbox. They have two rubber bits which sit in holders one of them popped out on mine and I lost 5th and 6th. Also check under heather the gearstick fairer in the car and see if the balljoint has popped off at the bottom
    Nov 2012
    wrexham
    Vehicle : signum
    Trim : elite
    Mileage : 129,000
    they both moving both ends it attached one moves freely the other is stiff
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Damage of the stiff one inside the sheathing perhaps ? Corrosion, cable fraying? Would be helpful to verify neither cable is being pinched or restricted along it's length as well.
    But based on one being free and the other stiff, looks like you may be better off replacing the pair of them.
    ... not forgetting of course, to make sure the gearbox fluid is in good condition and at the correct level.
    Nov 2012
    wrexham
    Vehicle : signum
    Trim : elite
    Mileage : 129,000
    yeh i will do ill pop them off and check them and check the oil in the box i have not check that tbh thanks
    Nov 2012
    wrexham
    Vehicle : signum
    Trim : elite
    Mileage : 129,000
    problem solved the selector pin had snapped ordered one from the dealer 3.31 thank god it was only that
    On the Forum
    540 Post(s)
    Engine : 150
    Mileage : 74000
    glad your getting it sorted
  1. getting gears
    By mitch in forum Engine & Drivetrain
    Last Post: 8th December 2010, 01:43
  2. Not enough gears!
    By Flaninacupboard in forum Vectra C / Signum Car Chat
    Last Post: 17th March 2010, 08:48
  3. How many gears
    By Jason123 in forum Vectra C / Signum Car Chat
    Last Post: 8th February 2009, 10:21
  4. how many gears in the 1.8 vvt?
    By jaff in forum Vectra C / Signum Car Chat
    Last Post: 15th January 2008, 19:09
  5. no gears - help!
    By Digital_kid in forum Engine & Drivetrain
    Last Post: 23rd May 2007, 13:53
vectra no gears
vectra c 1.8vvt wont select gear
